Good day to everyone.
Is it possible to display a list of AutoLISP commands before closing and saving the dwg file?
For example, in notepad or text in dwg.
I assume you're referring to commands defined in Lisp code.
One way to do this is to call ATOMS-FAMILY, save its contents in a variable, call ATOMS-FAMILY again when the drawing is about to be closed, compare the difference, and filter out symbols that don't begin with "c:"
But why do you need to do this?
1 hour ago, Lee Mac said:
Perhaps this old program?
https://lee-mac.com/lisplog.html
LISPLogV1-0.lsp is a very convenient program. Thanks @Lee Mac.
Is it possible to get a list of lisp commands in the drawing? That is, when saving a drawing, a request appears:
"Save a list of lisp commands?" and the text with the commands is inserted into the drawing?
I often have to go back to old drawings. I have over 300 lisp programs.
I would like the drawing to have a list of programs used to continue working,
but over time it is not always possible to remember the name of the desired program.
This could be one way to do it:
(defun fota (/ arch cad cmd)
  (defun pregunta (a b) (if (= (car b) "CLOSE") (if (= (vlax-invoke-method (vlax-create-object "wscript.shell") 'popup "Print commands on screen?" 0 "Nikon's doubts" 4) 6) (c:cmdsCargados))))
  (foreach sim (atoms-family 0)
    (if (wcmatch (setq cmd (strcase (vl-princ-to-string sim) T)) "c:*")
      (setq *afI* (cons sim *afI*))
  (setq *r* (vlr-command-reactor nil '((:vlr-commandwillStart . pregunta))))
(defun c:cmdsCargados (/ cad cadCmds arch linea)
    (if	(not (member sim *afI*))
      (if (wcmatch (setq cad (strcase (vl-princ-to-string sim) T)) "c:*")
	(setq cadCmds (strcat (if cadCmds (strcat cadCmds "\n") "\\C1Commands loaded during last sesion:\\C256\n") (substr cad 3)))
  (if cadCmds (vla-AddMText (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))) (vlax-3d-point (getpoint "\nInsertion point...")) 100 cadCmds))
(fota)
(fota)
How to make it work?
Locate your acad**doc.lsp file and copy the code at the end of the original code, but before any code you may have added yourself.
Try it.
  • Thanks 1
Once you've done this, after opening any drawing, the code will be loaded, and when you close the drawing, it should prompt you for a location point for an MTEXT with the loaded commands.
The only question I have is whether it's better to save this code in acad####Doc.lsp or acad####.lsp.
I open a new file, download, for example, 3 lisps, but when I close it, the text is saved indicating the number of programs, more than 3.
In my opinion, programs that are in startup are being displayed...
Edited by Nikon
I saved this code in acad2021Doc.lsp
