pyou Posted Saturday at 11:38 PM Posted Saturday at 11:38 PM (edited) Hi all I have many Closed 3dpolyline Triangles with 4 vertices each. Would it be possible with the help of lisp command to track all triangles and remove duplicates, please? Its the first and second vertices with same position. Thank you Edited Saturday at 11:39 PM by pyou Quote
Lee Mac Posted Sunday at 09:18 AM Posted Sunday at 09:18 AM OVERKILL should remove the duplicate vertices. Quote
pyou Posted Sunday at 06:36 PM Author Posted Sunday at 06:36 PM (edited) 13 hours ago, Lee Mac said: OVERKILL should remove the duplicate vertices. not in this case , unless i am doing something wrong. I have attached example dwg. Basically i had 3DFaces as Triangles and converted them using lisp into 3dpolyline Triangles, but it creates 4 Vertices for each Triangle, another lisp which supposed to create contours over triangles refusing to do so and say 3dpolylines are not closed polylines. sample.dwg Edited Sunday at 11:12 PM by pyou Quote
Tsuky Posted Sunday at 09:09 PM Posted Sunday at 09:09 PM Hi, With your drawing, this code will correct the polylines. To be adapted if used in another drawing (ssget filter) (vl-load-com) (defun c:Correct3DPL ( / ss AcDoc Space nb n ename obj l_pt lay new_obj) (setq ss (ssget "_X" '((0 . "POLYLINE") (67 . 0) (8 . "CTL_PNT") (66 . 1) (70 . 9)))) (cond (ss (setq AcDoc (vla-get-ActiveDocument (vlax-get-acad-object)) Space (if (= 1 (getvar "CVPORT")) (vla-get-PaperSpace AcDoc) (vla-get-ModelSpace AcDoc) ) nb 0 ) (repeat (setq n (sslength ss)) (setq ename (ssname ss (setq n (1- n))) obj (vlax-ename->vla-object ename) l_pt (vlax-get obj 'Coordinates) lay (vlax-get obj 'Layer) ) (cond ((eq (length l_pt) 12) (vla-delete obj) (setq new_obj (vlax-invoke Space 'Add3dPoly (cdddr l_pt))) (vla-put-Closed new_obj :vlax-true) (vla-put-Layer new_obj lay) (setq nb (1+ nb)) ) ) ) (princ (strcat "\n" (itoa nb) " polylines corrected.")) ) ) (prin1) ) 1 Quote
pyou Posted Sunday at 09:27 PM Author Posted Sunday at 09:27 PM 16 minutes ago, Tsuky said: Hi, With your drawing, this code will correct the polylines. To be adapted if used in another drawing (ssget filter) (vl-load-com) (defun c:Correct3DPL ( / ss AcDoc Space nb n ename obj l_pt lay new_obj) (setq ss (ssget "_X" '((0 . "POLYLINE") (67 . 0) (8 . "CTL_PNT") (66 . 1) (70 . 9)))) (cond (ss (setq AcDoc (vla-get-ActiveDocument (vlax-get-acad-object)) Space (if (= 1 (getvar "CVPORT")) (vla-get-PaperSpace AcDoc) (vla-get-ModelSpace AcDoc) ) nb 0 ) (repeat (setq n (sslength ss)) (setq ename (ssname ss (setq n (1- n))) obj (vlax-ename->vla-object ename) l_pt (vlax-get obj 'Coordinates) lay (vlax-get obj 'Layer) ) (cond ((eq (length l_pt) 12) (vla-delete obj) (setq new_obj (vlax-invoke Space 'Add3dPoly (cdddr l_pt))) (vla-put-Closed new_obj :vlax-true) (vla-put-Layer new_obj lay) (setq nb (1+ nb)) ) ) ) (princ (strcat "\n" (itoa nb) " polylines corrected.")) ) ) (prin1) ) Thank you Tsuky, works exactly as i needed. Quote
BIGAL Posted Sunday at 10:23 PM Posted Sunday at 10:23 PM Not sure if the lisp by YMG will read 3dfaces. CIV3d will do it same with other civil packages like Civil Site Design.TriangV0.6.7.LSP 1 Quote
pyou Posted Sunday at 10:41 PM Author Posted Sunday at 10:41 PM 17 minutes ago, BIGAL said: Not sure if the lisp by YMG will read 3dfaces. CIV3d will do it same with other civil packages like Civil Site Design.TriangV0.6.7.LSP Nice one Bigal, Thank you! Quote
GLAVCVS Posted 16 hours ago Posted 16 hours ago Another option: Keeping the original entity and removing any repeated points along the 3D polyline. (defun supriPts3DPol (e / l p lp vlae) (setq vlae (vlax-ename->vla-object e)) (while (/= (cdr (assoc 0 (setq l (entget (setq e (entnext e)))))) "SEQEND") (if (not (equal (setq p (cdr (assoc 10 l))) (car lp) 1e-4)) (setq lp (cons p lp))) ) (vlax-put vlae 'Coordinates (apply 'append (mapcar '(lambda(p) (mapcar 'float p)) lp))) ) Quote
