Add several lisp files to the startup at once
5 minutes ago, GLAVCVS said:
Maybe this will do what you need.
defun c:LoadFolder (/ sh hwd carp slf pth lstAA a arch nmarch nmarchLL cno cns sl r l)
  (setq sl (getvar "SECURELOAD"))
  (SETVAR "SECURELOAD" 0)
  (if (setq sh (vla-getinterfaceobject (vlax-get-acad-object) "shell.application")
	    hwd (vl-catch-all-apply 'vla-get-hwnd (list (vlax-get-acad-object)))
	    carp (vlax-invoke-method sh 'browseforfolder (if (vl-catch-all-error-p hwd) 0 hwd) "Folder to load" 0 "")
    (if (setq slf (vlax-get-property carp 'self)
	      pth (vlax-get-property slf 'path)
	      pth (vl-string-right-trim "\\" (vl-string-translate "/" "\\" pth))
      (if (setq lstAA (vl-directory-files pth "*.lsp"))
	(foreach a lstAA
	  (if (not arch)
	    (setq arch (open (setq nmarchLL
				    (strcase
				      (strcat
				        (VL-REGISTRY-READ
					  "HKEY_CURRENT_USER\\Software\\Microsoft\\Windows\\CurrentVersion\\Explorer\\Shell Folders"
					  "Personal"
				        "\\ListaLisps.lsp"
			     "w"
	  (load (strcat (setq cno (strcat pth "\\" a))))
;;;	  (princ (strcat "\n" cno "... *** LOADED ***"))
	  (write-line (strcat "(load \"" cno "\")") arch)
  (if arch
      (close arch)
;;;;;;      (startapp "notepad" nmarch)
      (princ (strcat "\n*** " (itoa (length lstAA)) " files LOADED ***"))
      (if (not (wcmatch (strcase pth) (setq cns (VLAX-get-property (setq prf (VLAX-get-property (vla-get-preferences (vlax-get-acad-object)) "files")) "SupportPath"))))
	  (vlax-put prf "SupportPath" (strcat cns ";" pth))
	  (princ (strcat "\n*** New SupportPath: " pth))
      (setq nmarch (if (setq a (findfile "acad.lsp")) a (strcat (vl-filename-directory (findfile "acad.exe")) "\\Support\\acad.lsp")))
      (if a (if (setq arch (open nmarch "r")) (progn (while (and (not r) (setq l (read-line arch))) (setq r (wcmatch (strcase l)  "(LOAD \"LISTALISPS.LSP\")"  ))) (close arch))))
      (cond
	((and a (not r))
	  (if (setq arch (open nmarch "a")) (progn (write-line "(LOAD \"LISTALISPS.LSP\")" arch) (close arch)))
	(a (princ) )
	(nmarch (if (setq arch (open nmarch "w")) (progn (write-line "(LOAD \"LISTALISPS.LSP\")" arch) (close arch))))
	(T (alert "Ocurrió lo inesperado"))
  (SETVAR "SECURELOAD" sl)
And what does it do?
The same as the previous command BUT ALSO:
– it writes into 'acad.lsp' Lisp code to load, from the next startup onward, the file 'ListaLisps.lsp', which in turn calls the loading of all the Lisp files in the selected folder.
– adds the location of the files to AutoCAD’s 'SupportPath'.
2 hours ago, Nikon said:
I use custom user names in acad.pgp, and for this the lisp files must be in the Startup Suite.
Why not use the acaddoc.lsp instead?
Thanks for participating, I'll try this code.
@Nikon
You should copy the code again.
I didn't paste the code correctly.
Also, I've also modified something.
  • Thanks 1
1 hour ago, GLAVCVS said:
@Nikon
I have checked the code, the files are uploaded to the drawing, but they are not uploaded to the startup.  In the new file, I need to use the code again.
At the end of the command execution, the acad.lsp file opens.
Make sure the full directory where "ListaLisps.lsp" is located appears.
It's possible that when loading the previous code, only the file name was written.
If this is the case, delete that line, save and close acad.lsp, and run the command again.
Something's wrong. A window appears
Edited by Nikon
