devitg Posted October 8 Posted October 8 There are or is a LISP editor outside ACAD own VLIDE , ? I have a student version , it allow to load LSP , but it do not edit it by VLIDE . Thanks in advance Quote
devitg Posted October 8 Author Posted October 8 29 minutes ago, Lee Mac said: VSCode? @Lee Mac Thanks I will try. Do VSCode allow to work as VLIDE , ? Quote
mhupp Posted October 8 Posted October 8 1 hour ago, devitg said: @Lee Mac Thanks I will try. Do VSCode allow to work as VLIDE , ? Yes, its their default now. have to set lispsys to 0 before it will work with vscode. https://help.autodesk.com/view/OARX/2021/ENU/?guid=GUID-037BF4D4-755E-4A5C-8136-80E85CCEDF3E Quote Obsolete Visual LISP IDE (Windows Only) - The Visual LISP (VL) IDE has been retired and will be removed in a future release. It is recommended to use the AutoCAD AutoLISP Extension for Visual Studio (VS) Code creating new and updating existing AutoLISP programs. LISPSYS must be set to 0 before the VL IDE can be used to edit and debug AutoLISP files. Quote
devitg Posted October 8 Author Posted October 8 18 minutes ago, mhupp said: Yes, its their default now. have to set lispsys to 0 before it will work with vscode. https://help.autodesk.com/view/OARX/2021/ENU/?guid=GUID-037BF4D4-755E-4A5C-8136-80E85CCEDF3E @mhupp ok . I will try to use the VSCode. ANy way what was the las ACAD version that have VLIDE inside , I run in W11 Quote
mhupp Posted October 8 Posted October 8 (edited) Link is for 2021 version. Edited October 8 by mhupp Quote
devitg Posted October 8 Author Posted October 8 12 minutes ago, mhupp said: Link is for 2021 version. @mhupp So I could understand that 2020 is the last that has VLIDE . Quote
mhupp Posted October 8 Posted October 8 (edited) @devitg That is my understanding, yes. I know BircsCAD still has it. Edited October 8 by mhupp Quote
devitg Posted October 8 Author Posted October 8 43 minutes ago, mhupp said: @devitg That is my understanding, yes. I know BircsCAD still has it. @mhupp Thanks Quote
SLW210 Posted October 9 Posted October 9 20 hours ago, devitg said: @mhupp ok . I will try to use the VSCode. ANy way what was the las ACAD version that have VLIDE inside , I run in W11 My AutoCAD 2026 has VLIDE, I still use it occasionally, the default is VSCODE. You may need this... AutoCAD AutoLISP Extension - Visual Studio Marketplace 1 Quote
devitg Posted October 9 Author Posted October 9 @all poster . I got to use Vlide at my 2024 . Not know how, but it work. Thans all you. Quote
Lee Mac Posted October 9 Posted October 9 (edited) You can enable VLIDE in newer releases by setting LISPSYS=0. https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-1853092D-6E6D-4A06-8956-AD2C3DF203A3 Edited October 9 by Lee Mac 2 Quote
