EYNLLIB Posted October 10, 2025 Posted October 10, 2025 I'm attempting to make a block with an attribute/field that when placed inside a pre-defined set of 4 coordinates (rectangle), the attribute field will update with a custom message. Anyone have any guidance with this? I'm guessing it will need a diesel expression, which I'm not all that familiar with. I'm hoping this is the right forum since it involves coding an expression Thanks Quote
BIGAL Posted October 10, 2025 Posted October 10, 2025 So if understand correctly you want to place a field value which says "This is inside area1 " You can certainly do as a lisp updating a value but not as a field. Not sure if you can do a COND in a field expression say looking at a multiple XY points. Quote
EYNLLIB Posted October 10, 2025 Author Posted October 10, 2025 7 minutes ago, BIGAL said: So if understand correctly you want to place a field value which says "This is inside area1 " You can certainly do as a lisp updating a value but not as a field. Not sure if you can do a COND in a field expression say looking at a multiple XY points. Yeah, I can easily do a lisp but I don't want to have my engineers have to run a lisp every time for this workflow. I'm trying to have detail numbers auto populate based on where the detail title is located. So if the detail title attribute is in a specific area of model space, it will always be 1/S3.0, etc Quote
BIGAL Posted October 10, 2025 Posted October 10, 2025 I probably can not help, but post a sample dwg so others can look at it. Quote
Danielm103 Posted October 10, 2025 Posted October 10, 2025 Nothing I can think of that’s built in, so you would have to roll something. With lisp, you would use an event to update the attributes, i.e. attached to regen There’s more options with ARX, .NET or Python - Create your own custom field - Create an Overrule that updates the attributes on close Quote
mhupp Posted October 10, 2025 Posted October 10, 2025 (edited) On 10/10/2025 at 12:13 AM, EYNLLIB said: Yeah, I can easily do a lisp but I don't want to have my engineers have to run a lisp every time for this workflow. I'm trying to have detail numbers auto populate based on where the detail title is located. So if the detail title attribute is in a specific area of model space, it will always be 1/S3.0, etc Have you looked into reactors to trigger the lisp? Never really used them didn't like the fact something is running without me knowing/realizing it. -Edit Would have to run this after ever copy or insert of a block to add a reactor to it. and i don't know how this affect the performance of the drawing. Edited October 12, 2025 by mhupp Quote
EYNLLIB Posted October 10, 2025 Author Posted October 10, 2025 2 hours ago, mhupp said: Have you looked into reactors to trigger the lisp? Never really used them didn't like the fact something is running without me knowing/realizing it. (defun block-modified-callback (reactor obj) (let* ( (ent (vlr-object-reactor-object reactor)) (pos (cdr (assoc 10 (entget ent)))) ) ;; Define your target area (example: lower-left (0,0), upper-right (10,10)) (if (and (>= (car pos) 0) (<= (car pos) 10) (>= (cadr pos) 0) (<= (cadr pos) 10) ) (princ "\nBlock moved into target area!") ;call lisp ? (princ "\nBlock moved outside target area.") ; ) ) ) (defun C:BlockReact ( / ss i ent obj) (setq ss (ssget "_X" '((0 . "INSERT")))) ;maybe limit to the blocks you want to update (if ss (progn (setq i 0) (while (< i (sslength ss)) (setq ent (ssname ss i)) (setq obj (vlr-object-reactor (vlax-ename->vla-object ent) nil '((:vlr-modified . block-modified-callback)))) (setq i (1+ i)) ) (princ "\nReactors attached to block references.") ) (princ "\nNo blocks found.") ) (princ) ) -Edit Would have to run this after ever copy or insert of a block to add a reactor to it. and i don't know how this affect the performance of the drawing. I've never worked with reactors. I'll have to dig into it. Thanks! Quote
Lee Mac Posted October 11, 2025 Posted October 11, 2025 20 hours ago, mhupp said: Have you looked into reactors to trigger the lisp? Never really used them didn't like the fact something is running without me knowing/realizing it. (defun block-modified-callback (reactor obj) (let* ( (ent (vlr-object-reactor-object reactor)) (pos (cdr (assoc 10 (entget ent)))) ) ;; Define your target area (example: lower-left (0,0), upper-right (10,10)) (if (and (>= (car pos) 0) (<= (car pos) 10) (>= (cadr pos) 0) (<= (cadr pos) 10) ) (princ "\nBlock moved into target area!") ;call lisp ? (princ "\nBlock moved outside target area.") ; ) ) ) (defun C:BlockReact ( / ss i ent obj) (setq ss (ssget "_X" '((0 . "INSERT")))) ;maybe limit to the blocks you want to update (if ss (progn (setq i 0) (while (< i (sslength ss)) (setq ent (ssname ss i)) (setq obj (vlr-object-reactor (vlax-ename->vla-object ent) nil '((:vlr-modified . block-modified-callback)))) (setq i (1+ i)) ) (princ "\nReactors attached to block references.") ) (princ "\nNo blocks found.") ) (princ) ) -Edit Would have to run this after ever copy or insert of a block to add a reactor to it. and i don't know how this affect the performance of the drawing. Don't create a new reactor for every object - this is likely to severely impact performance - only one object reactor is required with a set of owning objects. Aside, you're missing the definition for your (let*) function. 1 Quote
BIGAL Posted October 11, 2025 Posted October 11, 2025 If you use a reactor it is a lisp anyway and has to be ran every time you add the block, so as I suggested much easier to do a lisp that looks at the XY point and updates, a lisp will run through multiple blocks very fast and update all. Just make the lisp insert the block 1st. Quote
Steven P Posted October 12, 2025 Posted October 12, 2025 Reading this one, what is the objection to the engineers running a LISP? You could add it as a button, in the ribbon, or as a command to suit their preferences, and if you make it easier for them they'll use it. For example a single command to draw the rectangle and insert the block instead of 3 or 4 commands makes things quicker and easier, the engineers should jump on that (every speed improvement is after all another few seconds to go and make another coffee!) Quote
EYNLLIB Posted October 13, 2025 Author Posted October 13, 2025 On 10/12/2025 at 2:59 AM, Steven P said: Reading this one, what is the objection to the engineers running a LISP? You could add it as a button, in the ribbon, or as a command to suit their preferences, and if you make it easier for them they'll use it. For example a single command to draw the rectangle and insert the block instead of 3 or 4 commands makes things quicker and easier, the engineers should jump on that (every speed improvement is after all another few seconds to go and make another coffee!) The issue is CAD literacy within the office. One of my engineers would be fine to use it, but the rest are fairly CAD illiterate. I try to keep things as simple as possible (I know running a lisp command is simple to begin with) 1 Quote
Lee Mac Posted October 13, 2025 Posted October 13, 2025 I would suggest using a single command reactor to automatically update all blocks on save or plot - this is far simpler than using an object reactor to track modifications to each individual block reference. Quote
EYNLLIB Posted October 13, 2025 Author Posted October 13, 2025 7 minutes ago, Lee Mac said: I would suggest using a single command reactor to automatically update all blocks on save or plot - this is far simpler than using an object reactor to track modifications to each individual block reference. Probably a better idea. I have been looking into the object reactors and it was seeming like it was going to bog down the drawing immensely, since we will have dozens of these blocks in a single file. Thanks! Quote
Lee Mac Posted October 13, 2025 Posted October 13, 2025 Here's a proof-of-concept example for consideration - (defun update-attributes ( / bln idx ins map obj sel tag val ) (setq ;; List of ;; ((lower-left point) (upper-right point) "attribute value") map '( (( 0.0 0.0) (10.0 10.0) "abc") ((20.0 20.0) (30.0 30.0) "def") ) ;; Block name bln "YourBlock" tag "YourTag" ) (setq bln (strcase bln) tag (strcase tag) ) (if (setq sel (ssget "_X" (list '(0 . "INSERT") '(66 . 1) (cons 2 (strcat "`*U*," bln))))) (repeat (setq idx (sslength sel)) (setq idx (1- idx) obj (vlax-ename->vla-object (ssname sel idx)) ) (cond ( (/= bln (strcase (vlax-get-property obj (if (vlax-property-available-p obj 'effectivename) 'effectivename 'name))))) ( (setq ins (vlax-get obj 'insertionpoint) val (vl-some '(lambda ( itm ) (if (vl-every '<= (car itm) ins (cadr itm)) (caddr itm))) map) ) (vl-some '(lambda ( att ) (if (= tag (strcase (vla-get-tagstring att))) (progn (if (vlax-write-enabled-p att) (vla-put-textstring att val) ) t ) ) ) (vlax-invoke obj 'getattributes) ) ) ) ) ) ) (defun block-position-callback ( rtr arg ) (if (and arg (wcmatch (strcase (car arg) t) "qsave,save,saveas,plot,publish")) (update-attributes) ) (princ) ) ( (lambda ( key ) (vl-load-com) (foreach rtr (cdar (vlr-reactors :vlr-command-reactor)) (if (= key (vlr-data rtr)) (vlr-remove rtr) ) ) (vlr-set-notification (vlr-command-reactor key '( (:vlr-commandwillstart . block-position-callback) ) ) 'active-document-only ) (update-attributes) (princ) ) "block-position-reactor" ) There is no command to run the program: simply amend the block name, tag name, and map at the top of the code to suit your setup, and then load the program - the attributes will be automatically updated when the drawing is saved or plotted. 3 Quote
Danielm103 Posted October 13, 2025 Posted October 13, 2025 Nice, I was thinking AcFdFieldReactor because it has all those plus REGEN, but it’s not available to lisp. You might add REGEN to the list, so the user can see the updated values without needing to save or plot. 1 Quote
EYNLLIB Posted October 16, 2025 Author Posted October 16, 2025 On 10/13/2025 at 3:51 PM, Danielm103 said: You On 10/13/2025 at 3:06 PM, Lee Mac said: Here's a proof-of-concept example for consideration - (defun update-attributes ( / bln idx ins map obj sel tag val ) (setq ;; List of ;; ((lower-left point) (upper-right point) "attribute value") map '( (( 0.0 0.0) (10.0 10.0) "abc") ((20.0 20.0) (30.0 30.0) "def") ) ;; Block name bln "YourBlock" tag "YourTag" ) (setq bln (strcase bln) tag (strcase tag) ) (if (setq sel (ssget "_X" (list '(0 . "INSERT") '(66 . 1) (cons 2 (strcat "`*U*," bln))))) (repeat (setq idx (sslength sel)) (setq idx (1- idx) obj (vlax-ename->vla-object (ssname sel idx)) ) (cond ( (/= bln (strcase (vlax-get-property obj (if (vlax-property-available-p obj 'effectivename) 'effectivename 'name))))) ( (setq ins (vlax-get obj 'insertionpoint) val (vl-some '(lambda ( itm ) (if (vl-every '<= (car itm) ins (cadr itm)) (caddr itm))) map) ) (vl-some '(lambda ( att ) (if (= tag (strcase (vla-get-tagstring att))) (progn (if (vlax-write-enabled-p att) (vla-put-textstring att val) ) t ) ) ) (vlax-invoke obj 'getattributes) ) ) ) ) ) ) (defun block-position-callback ( rtr arg ) (if (and arg (wcmatch (strcase (car arg) t) "qsave,save,saveas,plot,publish")) (update-attributes) ) (princ) ) ( (lambda ( key ) (vl-load-com) (foreach rtr (cdar (vlr-reactors :vlr-command-reactor)) (if (= key (vlr-data rtr)) (vlr-remove rtr) ) ) (vlr-set-notification (vlr-command-reactor key '( (:vlr-commandwillstart . block-position-callback) ) ) 'active-document-only ) (update-attributes) (princ) ) "block-position-reactor" ) There is no command to run the program: simply amend the block name, tag name, and map at the top of the code to suit your setup, and then load the program - the attributes will be automatically updated when the drawing is saved or plotted. (defun update-attributes ( / bln idx ins map obj sel tag val ) (setq ;; List of ;; ((lower-left point) (upper-right point) "attribute value") map '( ((-1179.5 -1006.0) (1179.5 1006.0) "S3.0") ) ;; Block name bln "Detail Cut" tag "SHEETNUMBER" ) (setq bln (strcase bln) tag (strcase tag) ) (if (setq sel (ssget "_X" (list '(0 . "INSERT") '(66 . 1) (cons 2 (strcat "`*U*," bln))))) (repeat (setq idx (sslength sel)) (setq idx (1- idx) obj (vlax-ename->vla-object (ssname sel idx)) ) (if (= bln (strcase (vlax-get-property obj (if (vlax-property-available-p obj 'effectivename) 'effectivename 'name)))) (progn (setq ins (vlax-get obj 'insertionpoint) val (vl-some '(lambda ( itm ) (if (vl-every '<= (car itm) ins (cadr itm)) (caddr itm))) map) ) (if val (vl-some '(lambda ( att ) (if (= tag (strcase (vla-get-tagstring att))) (progn (if (vlax-write-enabled-p att) (vla-put-textstring att val) ) t ) ) ) (vlax-invoke obj 'getattributes) ) ) ) ) ) ) (princ) ) (defun block-position-callback ( rtr arg ) (if (and arg (wcmatch (strcase (car arg) t) "qsave,save,saveas,plot,publish,regen,regenall")) (update-attributes) ) (princ) ) ( (lambda ( key ) (vl-load-com) (foreach rtr (cdar (vlr-reactors :vlr-command-reactor)) (if (= key (vlr-data rtr)) (vlr-remove rtr) ) ) (vlr-set-notification (vlr-command-reactor key '( (:vlr-commandwillstart . block-position-callback) ) ) 'active-document-only ) (update-attributes) (princ) ) "block-position-reactor" ) For whatever reason the code you posted wasn't agreeing with my CAD. I inverted the logic to test if true, and added a nil guard to ensure attributes are only updated when a valid value is found in the area map Thanks for pointing me in the right direction! Quote
