Copy and paste error (blocks changes!)
I made a stupid mistake and now I would like to find a way to avoid it: I copied a portion of a drawing (using CTRL+C) and pasted it into another (CTRL+V). The problem is that the copied part contained blocks that were already present with the same name in the new drawing. However, the blocks in the new drawing were slightly different.
Is it possible to create a lisp or something that warns: 'Attention: the drawing already contains blocks named XXXX'?
Perhaps someone knows a better way.
In my opinion, this could be done with reactors.
That is, in your AutoCAD session, there should be two latent reactors: one that activates after "copyclip" is executed and looks for the most recent DWG in the "temp" folder and saves its name in a global variable; and another that activates just before "pasteclip" is executed (:vlr-commandWillStart) and tracks the blocks of the DWG where the "copyclip" was created and the blocks of the current drawing.
There may already be a Lisp published in this forum that does this job, and some veteran can help you locate it.
It would be nice to add a request along with the warning.:
(setq choice (getkword "[Continue/caNcel/Rename/Add-index-1] <Rename>: "))
Edited by Nikon
Thank you very much, I also thought that the solution was to use Reactors... but creating a Lisp of this kind is way beyond my abilities! I hope that someone among the 'gurus' of this forum can help me. Thank you.
Could do it with pure LISP rather than reactors, a new name though ("CopyWithBlocks" and "PasteWithBlocks" or something like that. CwB, PwB)
Weekend so CAD is off but something like this
Copy:
Select all the entities required in a selection set
Select the basepoint (or use a nominal one if necessary)
Loop through the selection set to find all the block names
Save this list as a variable - or if you want to be really clever - add this list to the copied information (never tried that but I think it is possible), perhaps as xdata in a point or something that can later be found and deleted
Copy to clipboard: (vl-cmdf "_.copyclip" basepoint MySS "")  (vl-cmdf "_.copybase" basepoint MySS "")
Paste:
Find the list of blocks from the xdata, and create a list of blocks in the target drawing
Compare the 2 lists and give any warnings necessary
If OK, paste. If not OK don't paste.
maybe something like this (untested)
;;; copy & paste for dummies - rlx 2025-10-18
(defun c:capfd ( / this-dwg ss other-dwg blocknames-in-selectionset blocknames-in-other-dwg duplicate-blocknames)
  (setq this-dwg (vla-get-ActiveDocument (vlax-get-acad-object)))
  (if (and (setq ss (ssget)) (setq other-dwg (getfiled "Copy SS to:" "" "dwg" 0)))
      (setq blocknames-in-selectionset (Get_SS_BlockNames ss))
      (setq blocknames-in-other-dwg (Get_DBX_Blocknames other-dwg))
      (setq duplicate-blocknames (compare_block_names blocknames-in-selectionset blocknames-in-other-dwg))
      (if (vl-consp duplicate-blocknames)
          (dplm duplicate-blocknames "Duplicated block names : ")
          (if (yes_no "Copy anyway?")
            (ctd ss other-dwg)
            (princ"\nBite me...")
        (ctd ss other-dwg)
(defun compare_block_names (a b / c)
  (and (vl-consp a) (vl-consp b) (foreach item a (if (member item b) (setq c (cons item c))))) c)
(defun Get_SS_BlockNames ( ss / n l)
  (foreach o (ss->ol ss)
    (if (and (block-p o)(not (member (setq n (block-n o)) l))) (setq l (cons n l)))) l)
(defun SS->OL (ss / i l)(setq i 0)(repeat (sslength ss)(setq l (cons (vlax-ename->vla-object (ssname ss i)) l) i (1+ i))) l)
; (block-p (vlax-ename->vla-object (car (entsel))))
(defun block-p (o) (and (= 'vla-object (type O))(eq (vla-get-objectname O) "AcDbBlockReference")))
(defun block-n (o) (if (and (= 'vla-object (type O))(eq (vla-get-objectname O) "AcDbBlockReference"))
  (if (vlax-property-available-p o 'EffectiveName)(vla-Get-EffectiveName o)(vla-Get-Name o)) nil))
; (yes_no "Do you like snow")
(defun yes_no ( $m / f p i r ) (and (= (type $m) 'STR) (setq f (vl-filename-mktemp ".dcl")) (setq p (open f "w"))
  (write-line (strcat "yesno:dialog{label=\"" $m "?\";ok_cancel;}") p) (progn (close p)(gc) t) (setq i (load_dialog f))
    (new_dialog "yesno" i) (progn (action_tile "accept" "(done_dialog 1)")(action_tile "cancel" "(done_dialog 0)")
      (setq r (start_dialog))(unload_dialog i)(vl-file-delete f) t)(if (= r 1) t nil)))
;;; display list (plus message)
(defun dplm (l m / f p d w) (and (vl-consp l) (setq l (mapcar 'vl-princ-to-string l)) (setq w (+ 5 (apply 'max (mapcar 'strlen l))))
  (setq p (open (setq f (vl-filename-mktemp ".dcl")) "w")) (princ (strcat "cfl:dialog{label=\"" m "\";:list_box {key=\"lb\";"
   "width="(itoa w)";}ok_only;}") p)(not (setq p (close p)))(< 0 (setq d (load_dialog f)))(new_dialog "cfl" d)(progn (start_list "lb")
     (mapcar 'add_list l)(end_list)(action_tile "accept" "(done_dialog)")(start_dialog)(unload_dialog d)(vl-file-delete f))))
;;; copy to drawing
(defun ctd ( ss dwg / ss->ol dbx_ver acApp acDoc dbx object-list object-safe-array)
  (defun dbx_ver ( / v)
    (strcat "objectdbx.axdbdocument" (if (< (setq v (atoi (getvar 'acadver))) 16) "" (strcat "." (itoa v)))))
  (setq acApp (vlax-get-acad-object) acDoc (vla-get-ActiveDocument acApp))
  (setq dbx (vl-catch-all-apply 'vla-getinterfaceobject (list acApp (dbx_ver))))
  (vla-open dbx dwg)
  ; put all block objects in a list
  (setq object-list (ss->ol ss))
  ; put list with objects in a safe array
  (setq object-safe-array (vlax-make-safearray vlax-vbobject (cons 0 (1- (length object-list)))))
  (vl-catch-all-apply 'vlax-safearray-fill (list object-safe-array object-list))
  ; copy objects to dbx-drawing
  (vla-CopyObjects acDoc object-safe-array (vla-get-ModelSpace dbx))
  (vl-catch-all-apply 'vla-saveas (list dbx dwg))
  (vl-catch-all-apply 'vlax-release-object (list dbx))
  (setq object-list nil object-safe-array nil)
; test : (setq lst (GetDocBlockNames (vla-get-ActiveDocument (vlax-get-acad-object))))
; returns sorted list (uppercase) like : ("BLOCK_A" "BLOCK_B" ...)
(defun GetDocBlockNames (d / o n l)
  (vlax-for o (vla-get-blocks d)(if (and (= :vlax-false (vla-get-isxref o))(= :vlax-false (vla-get-islayout o))
    (snvalid (setq n (vla-get-name o)) 0))(setq l (cons (strcase n) l))))(if (vl-consp l)(acad_strlsort l)))
(defun Get_DBX_Blocknames ( doc-name / lst v objectdbx-document)
  (cond
    ((not (eq (type doc-name) 'STR))
     (princ (strcat "\nInvalid filename : " (vl-princ-to-string doc-name))))
    ((not (findfile doc-name))
     (princ (strcat "\nFile not found : " (vl-princ-to-string doc-name))))
    (t
     (vlax-for doc (vla-get-Documents (vlax-get-acad-object))
       (and (eq (strcase (vla-get-fullname doc)) (strcase doc-name))(setq objectdbx-document doc)))
     (cond
       ((eq (type objectdbx-document) 'VLA-OBJECT))
       ((not (setq objectdbx-document (vlax-create-object (strcat "objectdbx.axdbdocument"
	  (if (< (setq v (atoi (getvar 'acadver))) 16) "" (strcat "." (itoa v)))))))
	(princ "\nUnable to start object dbx"))
       ((vl-catch-all-error-p (vl-catch-all-apply 'vla-open (list objectdbx-document doc-name)))
        (princ (strcat "\nOdbx error - unable to acces : " doc-name)))
       (t (setq lst (GetDocBlockNames objectdbx-document)))
  (vl-catch-all-apply 'vla-close (list objectdbx-document :vlax-False))
  (if (and (= 'vla-object (type objectdbx-document))(not (vlax-object-released-p objectdbx-document)))
    (vlax-release-object objectdbx-document))
  (if (vl-consp lst) (mapcar 'strcase lst))
and if you want the rename version :
;;; copy for lazy dummies - rlx 2025-10-18
(defun c:cfld ( / this-dwg ss other-dwg blocknames-in-selectionset blocknames-in-other-dwg duplicate-blocknames)
      (if (vl-consp (setq blocknames-in-selectionset (Get_SS_BlockNames ss)))
        (setq blocknames-in-selectionset (mapcar 'strcase blocknames-in-selectionset)))
      (if (vl-consp (setq blocknames-in-other-dwg (Get_DBX_Blocknames other-dwg)))
        (setq blocknames-in-other-dwg (mapcar 'strcase blocknames-in-other-dwg)))
          ;;; (if (yes_no "Copy anyway?") (ctd ss other-dwg) (princ"\nBite me...") )
          (if (yes_no "Rename duplicates?")
              (foreach b duplicate-blocknames (rename_block_definition b))
              (ctd ss other-dwg)
        (ctd ss other-dwg)
; check if $member exists in (vla-) %collection
(defun Collection-Member ( $member %collection  / result)
  (if (vl-catch-all-error-p (setq result (vl-catch-all-apply 'vla-item (list %collection $member)))) nil result))
(defun create_unique_blockname ( $bn / i bn)
  (setq i 0)(while (tblsearch "block" (setq bn (strcat $bn "_" (itoa (setq i (1+ i))))))) bn)
(defun rename_block_definition ( $bn / bn )
  (if (and (not (void $bn)) (tblsearch "block" $bn))
    (vla-put-name (Collection-Member $bn (vla-get-blocks (vla-get-ActiveDocument (vlax-get-acad-object))))
      (setq bn (create_unique_blockname $bn)))) bn)
;;; copy to drawing
  (vla-open dbx dwg)
  (cond
    (t
     (cond
(c:cfld)
Edited by rlx
  • Like 2
I tested both files: the 2nd one (the one that allows renaming), I don't understand how it works: I can't rename the block already present on the first drawing. ... but the first lisp is more than sufficient: from now on, whenever I want to do a "Copy and paste at the original coordinates", I will definitely use 'capdf.lsp'!
An 'Alert' that warns me there are blocks with the same name already present in the 2nd drawing... is more than enough to avoid making dangerous mistakes!
I thank you immensely, RLX, for all the work you have done!
A note (I also say this for other users): remember to add (vl-load-com), if it is not already included in the auto start when launching AutoCAD.
Edited by X11start
You're welcome @X11start
If you want options for rename you can try this copy for dragons version
;;; copy for dragons- rlx 2025-10-18
(defun c:cfd ( / this-dwg ss other-dwg blocknames-in-selectionset blocknames-in-other-dwg duplicate-blocknames dbx-doc)
          (setq inp (cfl (list "1 - Copy anyway" "2 - Rename blocks in this dwg" "3 - Rename blocks in other dwg" "4 - Never mind")))
          (cond
            ((void inp) (princ "\nNever mind"))
            ((wcmatch inp "1*") (ctd ss other-dwg))
            ((wcmatch inp "2*") (foreach b duplicate-blocknames (rename_block_definition b)) (ctd ss other-dwg))
            ((wcmatch inp "3*") (dbx_rename_block_definitions duplicate-blocknames other-dwg) (ctd ss other-dwg))
            (t (princ"\nBite me..."))
        (ctd ss other-dwg)
(defun void (x) (or (eq x nil)(and (listp x)(not (vl-consp x)))(and (eq 'STR (type x))(eq "" (vl-string-trim " \t\r\n" x)))))
;;; choose from list (cfl '("1""2""3"))
(defun cfl (l / f p d r) (and (setq p (open (setq f (vl-filename-mktemp ".dcl")) "w"))
 (princ "cfl:dialog{label=\"Choose\";:list_box{key=\"lb\";width=40;}ok_cancel;}" p)
   (progn (start_list "lb")(mapcar 'add_list l)(end_list)(action_tile "lb" "(setq r (nth (atoi $value) l))(done_dialog 1)")
    (action_tile "accept" "(setq r (get_tile \"lb\"))(done_dialog 1)")(action_tile "cancel" "(setq r nil)(done_dialog 0)")
     (start_dialog)(unload_dialog d)(vl-file-delete f))) (cond ((= r "") nil)(r r)(t nil)))
;;; copy to drawing
  (vla-open dbx dwg)
  ; put all objects in a list
;;; (dbx_rename_block_definitions ("block-a" "block-b" "block-c") "c:\\temp\\my-old-blocks-drawing.dwg")
(defun dbx_rename_block_definitions ( lst dwg / dbx_ver acApp acDoc dbx dbx-blocks)
  (defun dbx_ver ( / v) (strcat "objectdbx.axdbdocument"
  (vla-open dbx dwg)
  (setq dbx-blocks (vla-get-blocks dbx))
  (foreach blk lst (if (Collection-Member blk dbx-blocks)
    (vla-put-name (Collection-Member blk dbx-blocks) (create_unique_blockname blk))))
  (cond
    (t
     (cond
(c:cfd)
Edited by rlx
these days I also can't copy / paste / download on my worklaptop but will have a look tonight. Maybe make sure the drawing you copy to is closed. I only tested it once on my home laptop and had nos problemos you knowos... and maybe look for locked layers? Just hope I can still post...
... Don't worry: take it slow.
Even my home PC went crazy yesterday: the screen was filled with colored squares and everything froze!
These PCs are unpredictable... like a woman! Maybe that's their charm!
well , downloaded your files on my homedragon and no errors on my side , maybe others can give it a go and see if they get an error?
... I didn't tell you that I use GStarCAD: this would be one of the very rare cases where an AutoCAD lisp is not compatible with GStarCAD!
I need to try it on a co-worker PC: they use AutoCAD LT (which should now make the lisps work... let's hope also the VL-XXX ones!).
Anyway, thank you for your availability.
I checked: it works on Autocad... on GstarCAD it doesn't work.
It doesn't matter, I use your previous file that reported the error but didn't allow renaming (CAPFD)
thank you so much RLX for your effort!
  • Thanks 1
... I tried replacing 'objectdbx.axdbdocument' with 'GStarX.axdbdocument': it keeps giving me the error VLA-OBJECT #<%catch-all-apply-error%>
Then it is possible that your version of GStarCAD does not have access to DBX from Lisp.
If you have a debugger (for GStarCAD, VS Code I suppose), the ideal would be to put a breakpoint in the code at the end of this line:
"(setq acApp (vlax-get-acad-object) acDoc (vla-get-ActiveDocument acApp))"
and this:
"(setq dbx (vl-catch-all-apply 'vla-getinterfaceobject (list acApp (dbx_ver))))"
And then run it again
If the code runs up to the first breakpoint and then continues execution and doesn't stop again at the next breakpoint because the error occurs first, the problem is access to DBX
I'm a little confused , you say the first lisp gives a warning about duplicate block names in the second drawing and that's also dbx , so maybe its the renaming part that uses commands not supported by GStarCad?
... in fact, ALL (CFD CFLD CAPFD) give me an error: I don't know what I did the first time I used the first file, it even worked on GStarCAD. If I remember correctly, I ran the command with the selection in progress... who knows (!) apparently I bypassed something... but now I can't replicate those steps.
