CivilTechSource Posted October 19, 2025 Posted October 19, 2025 Hi again, Looking to create a lisp that will bring a block into a drawing and will loop and keep adding it. The catch is that I want to see the visual of the block similar to the -insert command. So I managed to achieve the visual by adding the pause. But how do I make the while loop keep going without the getpoint? Is there a way I could check for pause? Thanks again (while (setq ins (getpoint "\nSpecify point for block (ENTER to exit): ")) (command "-INSERT" GV-Block pause "" "" "0") ) Quote
CivilTechSource Posted October 19, 2025 Author Posted October 19, 2025 I think I solved it. Is this the most optimal way? (while continue (command "-INSERT" GV-Block pause "" "" "0") (if (= (getvar "CMDSTAT") 0) (setq continue nil) ) ) Quote
devitg Posted October 19, 2025 Posted October 19, 2025 1 hour ago, CivilTechSource said: I think I solved it. Is this the most optimal way? (while continue (command "-INSERT" GV-Block pause "" "" "0") (if (= (getvar "CMDSTAT") 0) (setq continue nil) ) ) @CivilTechSource Quote Command: CMDSTAT Unknown command "CMDSTAT". Press F1 for help. Quote
Steven P Posted October 19, 2025 Posted October 19, 2025 (edited) If it is just a stand alone action, this will work but you have to escape out of it to cancel - you cannot have more to the routine, so stand alone only (while (= (command "-INSERT" GV-Block pause "" "" "0") nil) ) or this (while (setq pt1 (getpoint "Press LH Mouse to repeat, Enter / Space cancel")) (= (command "-insert" "circuitBreaker" pause 1 1 0) nil) ) Edited October 19, 2025 by Steven P 1 Quote
Lee Mac Posted October 20, 2025 Posted October 20, 2025 Depending on your version of CAD, you can use this: (defun c:test ( ) (command "_.-insert" "yourblockname" "_s" 1 "_r" 0 "_re" "_y") (while (= 1 (logand 1 (getvar 'cmdactive))) (command "\\")) (princ) ) 1 1 Quote
CivilTechSource Posted October 21, 2025 Author Posted October 21, 2025 So the first line keeps doing the loop while it is not nil? How will it know it is not nil? On 19/10/2025 at 16:37, Steven P said: If it is just a stand alone action, this will work but you have to escape out of it to cancel - you cannot have more to the routine, so stand alone only (while (= (command "-INSERT" GV-Block pause "" "" "0") nil) ) or this (while (setq pt1 (getpoint "Press LH Mouse to repeat, Enter / Space cancel")) (= (command "-insert" "circuitBreaker" pause 1 1 0) nil) ) Quote
CivilTechSource Posted October 21, 2025 Author Posted October 21, 2025 I am still new with Lisp, but it feels that this is more elegant by checking if a command is active? On 20/10/2025 at 08:45, Lee Mac said: Depending on your version of CAD, you can use this: (defun c:test ( ) (command "_.-insert" "yourblockname" "_s" 1 "_r" 0 "_re" "_y") (while (= 1 (logand 1 (getvar 'cmdactive))) (command "\\")) (princ) ) Quote
Lee Mac Posted October 21, 2025 Posted October 21, 2025 16 minutes ago, CivilTechSource said: So the first line keeps doing the loop while it is not nil? How will it know it is not nil? It won't - it will continue indefinitely until the user presses Esc to force it to exit. 2 Quote
Lee Mac Posted October 21, 2025 Posted October 21, 2025 14 minutes ago, CivilTechSource said: I am still new with Lisp, but it feels that this is more elegant by checking if a command is active? If you need more information, check the documentation on the CMDACTIVE system variable. 2 Quote
Steven P Posted October 21, 2025 Posted October 21, 2025 59 minutes ago, CivilTechSource said: So the first line keeps doing the loop while it is not nil? How will it know it is not nil? As Lee says, it doesn't know, it is a bit of a blunt LISP that does the job and no more. Lees is much better but I had a mental block yesterday, couldn't remember cmdactive. Quote
Lee Mac Posted October 21, 2025 Posted October 21, 2025 For completeness, the key here is the "Repeat" option of the -INSERT command - though, I'm unsure in which version this relatively new keyword was introduced. 2 Quote
ScottMC Posted October 23, 2025 Posted October 23, 2025 (edited) Thanks Lee.. you continue to inspire many. (defun c:mbi ( / *error* nobi p) (princ "\n Multi-Insert Block w.Total <!pp> ..") (defun *error* ( msg ) (setvar 'cmdecho 0) ;; 5.28.24 (vla-endundomark (vla-get-activedocument (vlax-get-acad-object))) (if msg (prompt (strcat "\n" msg))) (setvar 'cmdecho 1) (princ) ) (defun ccv ( / p) (setq p (getvar 'lastpoint)) (princ (setq pp ;; make/prints coords & paste usable (strcat " | " (rtos (car p) 2 4) "," ;; 'p' -- vertex from getpoint,... (rtos (cadr p) 2 4) "," (rtos (caddr p) 2 4) ) ) ) ) (command "DDINSERT" "\\") (setvar 'cmdecho 0) (setq nobi 1) (princ (strcat "\n Tot: " (rtos nobi))) (ccv) ;; coords (while T ;; insert loop of selected block (setq nobi (1+ nobi)) (princ (strcat "\n Tot: " (rtos nobi))) (command "_.-INSERT" "" "_s" 1 "_r" 0 "\\") ;; "_y") ; (ccv) ;; coords ) (*error* nil) (princ) ) Edited October 23, 2025 by ScottMC first file attach.. rather it be as theswamp [code][/code] Quote
mhupp Posted October 23, 2025 Posted October 23, 2025 looks like your command outputs like Tot: 1 | x, y, z Tot: 2 | x, y, z Tot: 3 | x, y, z Another option if you just using that output for checking use the status line with modemacro tho it would only be the last count / point info ;;----------------------------------------------------------------------------;; ;; Insert Block with Tot: Count and X, Y, Z output into status bar (defun c:mbi ( / *error* nobi p doc) (vl-load-com) (vla-startundomark (setq doc (vla-get-activedocument (vlax-get-acad-object)))) (princ "\n Multi-Insert Block w.Total <!pp> ..") (command "DDINSERT" "\\") (setvar 'cmdecho 0) (setq nobi 1) (ccv nobi) (while T ;; insert loop of selected block (command "_.-INSERT" "" "_s" 1 "_r" 0 "\\") ;; "_y") ; (setq nobi (+1 nobi) (ccv nobi) ;passes nobi to ccv as i ) (vla-endundomark doc) (setvar 'MODEMACRO "") (setvar 'cmdecho 1) (princ) ) (defun ccv (i / p str) (setq p (getvar 'lastpoint)) (setq str (strcat "Tot: " (rtos i) " | " (rtos (car p) 2 4) "," (rtos (cadr p) 2 4) "," (rtos (caddr p) 2 4))) (SETVAR 'MODEMACRO str) ) Quote
