Hi again,
Looking to create a lisp that will bring a block into a drawing and will loop and keep adding it. The catch is that I want to see the visual of the block similar to the -insert command. So I managed to achieve the visual by adding the pause. But how do I make the while loop keep going without the getpoint? Is there a way I could check for pause?
Thanks again
(while (setq ins (getpoint "\nSpecify point for block (ENTER to exit): "))
	(command "-INSERT" GV-Block pause "" "" "0")
I think I solved it. Is this the most optimal way?
(while continue
	(if (= (getvar "CMDSTAT") 0)
	(setq continue nil)
(while continue
	(setq continue nil)
@CivilTechSource
Quote
Command: CMDSTAT
Unknown command "CMDSTAT".  Press F1 for help.
If it is just a stand alone action, this will work but you have to escape out of it to cancel - you cannot have more to the routine, so stand alone only
(while (= (command "-INSERT" GV-Block pause "" "" "0") nil) )
or this
(while (setq pt1 (getpoint "Press LH Mouse to repeat, Enter / Space cancel"))
    (= (command "-insert" "circuitBreaker" pause 1 1 0) nil)
Edited by Steven P
