I found a lisp to adjust mtext color to bycolor but it shows the color code after adjusting. Please help me to adjust it and only remove the code before the text! Thank you.
I want it like this
mtext : room (color cycan) to room (bylayer)
lisp : room(color cycan) to 4:room (bylayer(
(defun c:MtextToByLayer (/ ss ent elist newtext)
  (princ "\nSelect Mtext objects to set to ByLayer.")
  (if (setq ss (ssget '((0 . "MTEXT")))) ; Select only MTEXT entities
      (vlax-for ent (vla-get-ActiveSelectionSet (vla-get-ActiveDocument (vlax-get-acad-object)))
        (if (= (vla-get-ObjectName ent) "AcDbMText")
            ; Set the entity color to ByLayer (color code 256)
            (vla-put-color ent 256)
            ; Get the Mtext content
            (setq elist (entget (vlax-vla-object->ename ent)))
            (setq newtext (cdr (assoc 1 elist)))
            ; Strip all internal formatting codes, including color
            (setq newtext (vl-string-subst "" "{\\C" newtext)) ; Removes color codes
            (setq newtext (vl-string-subst "" "\\c" newtext)) ; Removes inline color codes
            (while (vl-string-search "{" newtext)
              (setq newtext (vl-string-subst "" "{" newtext))
              (setq newtext (vl-string-subst "" "}" newtext))
            ; Update the Mtext entity with the stripped text
            (vla-put-TextString ent newtext)
      (princ (strcat "\n" (itoa (sslength ss)) " Mtext objects updated."))
    (princ "\nNo Mtext objects selected.")
Edited by SLW210
Added Code Tags!!
Please use Code Tags for your code in the future. (<> in the editor toolbar)
Try this code, calling with command: MtextToByLayerNoNum
(defun _strip-mtext-color (s / i j)
  ;; Deletes all occurrences \C<number>; and \c<number>;
  (setq i 0)
  (while (setq i (vl-string-search "\\C" s i))
    (if (setq j (vl-string-search ";" s i))
      (setq s (strcat (substr s 1 i) (substr s (+ j 2)))  i i)
      (setq s (substr s 1 i))
  (setq i 0)
  (while (setq i (vl-string-search "\\c" s i))
  s
(defun c:MtextToByLayerNoNum (/ ss ent elist newtext)
            (setq newtext (_strip-mtext-color newtext))
Edited by Nikon
