gbradley Posted October 23, 2025 Posted October 23, 2025 How do I put 7 1/2 " -12 thread on the inside of a 7.409 " hole ANSI Unified screw threads only go up to 4 inches Quote
SLW210 Posted October 24, 2025 Posted October 24, 2025 You'll need to make it. C:\Users\Public\Documents\Autodesk\Inventor <version>\Design Data\XLS and modify the Threads.xls, you might need to also alter the Clearance.xls, be sure to Save the originals some where, I usually just Saves and add _Original to the name. It's been a while since I used Inventor, but pretty sure it's just the case of adding the new information, make sure they are saved to correct location and are correctly named Threads.xls and Clearance.xls, when you restart Inventor they should be there. Quote
gbradley Posted October 27, 2025 Author Posted October 27, 2025 On 10/24/2025 at 3:33 AM, SLW210 said: You'll need to make it. C:\Users\Public\Documents\Autodesk\Inventor <version>\Design Data\XLS and modify the Threads.xls, you might need to also alter the Clearance.xls, be sure to Save the originals some where, I usually just Saves and add _Original to the name. It's been a while since I used Inventor, but pretty sure it's just the case of adding the new information, make sure they are saved to correct location and are correctly named Threads.xls and Clearance.xls, when you restart Inventor they should be there. Worked Great! Thanks for the tip. Quote
