Danielm103 Posted October 25 Posted October 25 (edited) sample of this import traceback import re from pyrx import Db, Ed, Ge, Ap, Rx, Gs def extract_num(s: str): match = re.search(r'\d+', s) if match: return int(match.group()) return -1 @Ap.Command() def doit(): try: # select db = Db.curDb() filter = [(Db.DxfCode.kDxfStart, "TEXT,LWPOLYLINE")] ps, ss = Ed.Editor.select(filter) if ps != Ed.PromptStatus.eOk: raise RuntimeError("Selection Error! {}: ".format(ps)) texts = [Db.Text(id) for id in ss.objectIds(Db.Text.desc())] plines = [Db.Polyline(id) for id in ss.objectIds(Db.Polyline.desc())] # make kdtree & list of points pntmap = {} plpoints = [] for pl in plines: plpoints.append(pl.getStartPoint()) plpoints.append(pl.getEndPoint()) pntmap[pl.getStartPoint()] = pl pntmap[pl.getEndPoint()] = pl # search closest pline results = [] tree = Ge.Point3dTree(plpoints) for text in texts: idxs, _ = tree.knnSearch(text.position(), 1) pl: Db.Polyline = pntmap[plpoints[idxs[0]]] results.append([text.textString(), pl.getDistAtParam(pl.getEndParam())]) # format mtext results = sorted(results, key=lambda x: extract_num(x[0])) buffer = "{:<6}\t{}\\P".format("S.No", "Length Ft") buffer += "".join(f"{sno:<6}\t {plen:>.2f}\\P" for sno, plen in results) # make mtext, add to currentSpace ps, pnt = Ed.Editor.getPoint("\nPick Text Position") mt = Db.MText() mt.setDatabaseDefaults(db) mt.setLocation(pnt) mt.setContents(buffer) cs = db.currentSpace(Db.OpenMode.kForWrite) cs.appendAcDbEntity(mt) except Exception as err: traceback.print_exception(err) Edited October 28 by Danielm103 1 Quote
BIGAL Posted October 25 Posted October 25 (edited) Would a table answer be perhaps neater than Mtext ? Just ask for text size for table. Edited October 25 by BIGAL Quote
Danielm103 Posted October 25 Author Posted October 25 Yep, easier too, since there would be not need to format the string for MText. Even though Python has robust string operations, it’s still weird to get it perfect https://docs.python.org/3/library/string.html I was just following along the original sample. The part I wanted to illustrate was, using a hashmap for mapping points to objects, and using the KD-Tree to do the spatial search I wrote the same KD-Tree and map for AutoLISP, I’m just really bad at lisp, so it’s hard for me to make samples lol https://github.com/CEXT-Dan/ads_geo 1 Quote
BIGAL Posted October 25 Posted October 25 (edited) Just a comment done a lot of find object next to text, just used get text insertion point, then use "ssget "F" pts" the pts are say 10 points made via a polar defun looking like a circle . I noticed you go the other way around looking around the pline for the text. Would be good to get a true sample dwg. Edited October 25 by BIGAL Quote
Danielm103 Posted October 25 Author Posted October 25 Yeah, I chose to search for the closest polyline to the text. BricsCAD has ssget crossing circle , (ssget "CC" point1 point2), could be similar to a radius search. Caveat, you’d have to call ssget for every mtext There’s a .DWG in the original post in the lisp forums Quote
Danielm103 Posted October 25 Author Posted October 25 I used a similar approach here, the user wanted to set the elevation of the contour lines to the nearest label. This is where KD-Trees really start to shine as they can handle millions of points, with millions of searches 1 Quote
Tamim Posted October 27 Posted October 27 On 25/10/2025 at 15:29, Danielm103 said: sample of this import traceback from pyrx import Db, Ed, Ge, Ap, Rx, Gs @Ap.Command() def doit(): try: # select db = Db.curDb() filter = [(Db.DxfCode.kDxfStart, "TEXT,LWPOLYLINE")] ps, ss = Ed.Editor.select(filter) if ps != Ed.PromptStatus.eOk: raise RuntimeError("Selection Error! {}: ".format(ps)) texts = [Db.Text(id) for id in ss.objectIds(Db.Text.desc())] plines = [Db.Polyline(id) for id in ss.objectIds(Db.Polyline.desc())] # make kdtree & list of points pntmap = {} plpoints = [] for pl in plines: plpoints.append(pl.getStartPoint()) plpoints.append(pl.getEndPoint()) pntmap[pl.getStartPoint()] = pl pntmap[pl.getEndPoint()] = pl # search closest pline results = [] tree = Ge.Point3dTree(plpoints) for text in texts: idxs, _ = tree.knnSearch(text.position(), 1) pl: Db.Polyline = pntmap[plpoints[idxs[0]]] results.append([text.textString(), pl.getDistAtParam(pl.getEndParam())]) # format mtext results = sorted(results, key=lambda x: int(x[0][2:])) buffer = "{:<6}\t{}\\P".format("S.No", "Length Ft") buffer += "".join(f"{sno:<6}\t {plen:>.2f}\\P" for sno, plen in results) # make mtext, add to currentSpace ps, pnt = Ed.Editor.getPoint("\nPick Text Position") mt = Db.MText() mt.setDatabaseDefaults(db) mt.setLocation(pnt) mt.setContents(buffer) cs = db.currentSpace(Db.OpenMode.kForWrite) cs.appendAcDbEntity(mt) except Exception as err: traceback.print_exception(err) How to use CAD? Quote
