maahee Posted October 25, 2025 Posted October 25, 2025 (defun C:bm () (setvar "osmode" 0) ; Turn off OSNAP (setq obj (ssget '((0 . "LWPOLYLINE,ARC")))) (setq num (sslength obj)) (setq i 0) (repeat num (setq obj1 (ssname obj i)) (setq db (entget obj1)) (if (= (cdr (assoc 0 db)) "ARC") (progn (setq ct (cdr (assoc 10 db))) (setq rd (cdr (assoc 40 db))) (setq ang1 (* (cdr (assoc 50 db)) (/ 180.0 pi)) ang2 (* (cdr (assoc 51 db)) (/ 180.0 pi)) ) (setq p1 (polar ct ang1 rd)) (setq p2 (polar ct ang2 rd)) (command "_.dimradius" "_non" p1 "_non" p2 "") (command "_.dimarc" "_non" p1 "_non" p2 "") ) ;progn (progn ;polyline arc segment ;;;;;code (if (/= bulge 0.0) (progn (setq p1 (nth r ptlist)) (setq p2 (nth (+ r 1) ptlist)) (command "_.dimradius" "_non" p1 "_non" p2 "") (command "_.dimarc" "_non" p1 "_non" p2 "") ; ) ;progn ) ;if ) ;progn ) (setq i (1+ i)) ) ;repeat end ; Turn off OSNAP (setvar "osmode" 511) (princ) ) ;end 1. It does not obtain dimensions for all arc objects. 2. It does not obtain the dimensions of all polyline arc segments. (command "_.dimradius" "_non" p1 "_non" p2 "") (command "_.dimarc" "_non" p1 "_non" p2 "") ; Quote
devitg Posted October 25, 2025 Posted October 25, 2025 1 hour ago, maahee said: (defun C:bm () (setvar "osmode" 0) ; Turn off OSNAP (setq obj (ssget '((0 . "LWPOLYLINE,ARC")))) (setq num (sslength obj)) (setq i 0) (repeat num (setq obj1 (ssname obj i)) (setq db (entget obj1)) (if (= (cdr (assoc 0 db)) "ARC") (progn (setq ct (cdr (assoc 10 db))) (setq rd (cdr (assoc 40 db))) (setq ang1 (* (cdr (assoc 50 db)) (/ 180.0 pi)) ang2 (* (cdr (assoc 51 db)) (/ 180.0 pi)) ) (setq p1 (polar ct ang1 rd)) (setq p2 (polar ct ang2 rd)) (command "_.dimradius" "_non" p1 "_non" p2 "") (command "_.dimarc" "_non" p1 "_non" p2 "") ) ;progn (progn ;polyline arc segment ;;;;;code (if (/= bulge 0.0) (progn (setq p1 (nth r ptlist)) (setq p2 (nth (+ r 1) ptlist)) (command "_.dimradius" "_non" p1 "_non" p2 "") (command "_.dimarc" "_non" p1 "_non" p2 "") ; ) ;progn ) ;if ) ;progn ) (setq i (1+ i)) ) ;repeat end ; Turn off OSNAP (setvar "osmode" 511) (princ) ) ;end 1. It does not obtain dimensions for all arc objects. 2. It does not obtain the dimensions of all polyline arc segments. (command "_.dimradius" "_non" p1 "_non" p2 "") (command "_.dimarc" "_non" p1 "_non" p2 "") ; @maahee Please upload you sample,dwg . as to test 1 Quote
Tsuky Posted October 25, 2025 Posted October 25, 2025 A start with this ? (vl-load-com) (defun make_mlead (pt o r obj / ptlst arr nw_obj) (setq ptlst (append pt (polar pt o r)) arr (vlax-make-safearray vlax-vbdouble (cons 0 (- (length ptlst) 1))) ) (vlax-safearray-fill arr ptlst) (setq nw_obj (vla-addMLeader Space (vlax-make-variant arr) 0)) (vla-put-contenttype nw_obj acMTextContent) (vla-put-textstring nw_obj (strcat "{\\fArial|b0|i0|c0|p34;R=" (rtos r 2 2) "\\P\\C1You can put here other value}")) (vla-put-layer nw_obj (getvar "CLAYER")) (vla-put-ArrowheadSize nw_obj (* (getvar "TEXTSIZE") 0.5)) (vla-put-TextHeight nw_obj (getvar "TEXTSIZE")) (if (> (car ptlst) (cadddr ptlst)) (progn (vla-SetDogLegDirection nw_obj 0 (vlax-3D-point '(-1.0 0.0 0.0))) (vla-put-TextJustify nw_obj acAttachmentPointMiddleRight) (vla-setLeaderLineVertices nw_obj 0 (vlax-make-variant arr)) ) (vla-put-TextJustify nw_obj acAttachmentPointMiddleLeft) ) (vla-update nw_obj) ) (defun c:rad2lead ( / ent dxf_ent typ_ent mkv vector vlaobj prm id_rad AcDoc Space ent pt1 pt2 pt x) (while (not (setq ent (entsel "\nSelect a bulge: ")))) (setq typ_ent (cdr (assoc 0 (setq dxf_ent (entget (car ent)))))) (cond ((or (eq typ_ent "ARC") (eq typ_ent "CIRCLE") (eq typ_ent "LWPOLYLINE") (and (eq typ_ent "POLYLINE") (zerop (boole 1 120 (cdr (assoc 70 dxf_ent)))) ) ) (if (or (> (fix (car (trans (cadr ent) 1 0))) 1E6) (> (fix (cadr (trans (cadr ent) 1 0))) 1E6)) (setq mkv T vector (trans (cadr ent) 0 0 T) vlaobj (vlax-ename->vla-object (car ent))) (setq mkv nil) ) (if mkv (vla-move vlaobj (vlax-3d-point (trans (cadr ent) 1 0)) (vlax-3d-point '(0.0 0.0 0.0)))) (setq id_rad (distance '(0 0) (trans (vlax-curve-getsecondderiv (car ent) (setq prm (vlax-curve-getparamatpoint (car ent) (vlax-curve-getclosestpointto (car ent) (if mkv '(0.0 0.0 0.0) (trans (cadr ent) 1 0))) ) ) ) 0 (car ent) T ) ) ) (if mkv (vla-move vlaobj (vlax-3d-point '(0.0 0.0 0.0)) (vlax-3d-point vector))) (cond ((not (zerop id_rad)) (setq AcDoc (vla-get-ActiveDocument (vlax-get-acad-object)) Space (if (= 1 (getvar "CVPORT")) (vla-get-PaperSpace AcDoc) (vla-get-ModelSpace AcDoc) ) ) (vla-startundomark AcDoc) (setq ent (car ent)) (if (member typ_ent '("POLYLINE" "LWPOLYLINE")) (setq pt1 (vlax-curve-getPointAtParam ent (fix prm)) pt2 (vlax-curve-getPointAtParam ent (1+ (fix prm))) pt (vlax-curve-getPointAtParam ent (+ (fix prm) 0.5)) ) (setq pt1 (vlax-curve-getStartPoint ent) pt2 (vlax-curve-getEndPoint ent) pt (vlax-curve-getPointAtDist ent (* 0.5 (- (vlax-curve-getDistAtPoint ent pt2) (vlax-curve-getDistAtPoint ent pt1)))) ) ) (setq x (* (fix (/ (angle (mapcar '* (mapcar '+ pt1 pt2) '(0.5 0.5 0.5)) pt) (* 0.125 pi))) 0.125 pi) x (+ x (rem x (* 0.25 pi))) ) (make_mlead pt x id_rad (vlax-ename->vla-object ent)) (vla-regen AcDoc acactiveviewport) (vla-endundomark AcDoc) ) (T (princ "\nSegment have no bulge.")) ) ) (T (princ "\nThis object can't be availaible for this function!")) ) (prin1) ) 1 Quote
GLAVCVS Posted October 25, 2025 Posted October 25, 2025 9 hours ago, maahee said: (defun C:bm () (setvar "osmode" 0) ; Turn off OSNAP (setq obj (ssget '((0 . "LWPOLYLINE,ARC")))) (setq num (sslength obj)) (setq i 0) (repeat num (setq obj1 (ssname obj i)) (setq db (entget obj1)) (if (= (cdr (assoc 0 db)) "ARC") (progn (setq ct (cdr (assoc 10 db))) (setq rd (cdr (assoc 40 db))) (setq ang1 (* (cdr (assoc 50 db)) (/ 180.0 pi)) ang2 (* (cdr (assoc 51 db)) (/ 180.0 pi)) ) (setq p1 (polar ct ang1 rd)) (setq p2 (polar ct ang2 rd)) (command "_.dimradius" "_non" p1 "_non" p2 "") (command "_.dimarc" "_non" p1 "_non" p2 "") ) ;progn (progn ;polyline arc segment ;;;;;code (if (/= bulge 0.0) (progn (setq p1 (nth r ptlist)) (setq p2 (nth (+ r 1) ptlist)) (command "_.dimradius" "_non" p1 "_non" p2 "") (command "_.dimarc" "_non" p1 "_non" p2 "") ; ) ;progn ) ;if ) ;progn ) (setq i (1+ i)) ) ;repeat end ; Turn off OSNAP (setvar "osmode" 511) (princ) ) ;end 1. It does not obtain dimensions for all arc objects. 2. It does not obtain the dimensions of all polyline arc segments. (command "_.dimradius" "_non" p1 "_non" p2 "") (command "_.dimarc" "_non" p1 "_non" p2 "") ; Your code, ready. (defun C:bm (/ obj num i obj1 db ct rd ang1 ang2 p1 p2 r ptlist) (setvar "osmode" 0) ; Turn off OSNAP (setq obj (ssget '((0 . "LWPOLYLINE,ARC")))) (setq num (sslength obj)) (setq i 0) (repeat num (setq obj1 (ssname obj i)) (setq db (entget obj1) ptlist (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) db)) i 0 ) (if (= (cdr (assoc 0 db)) "ARC") (progn (setq ct (cdr (assoc 10 db))) (setq rd (cdr (assoc 40 db))) (setq ang1 (* (cdr (assoc 50 db)) (/ 180.0 pi)) ang2 (* (cdr (assoc 51 db)) (/ 180.0 pi)) ) (setq p1 (polar ct ang1 rd)) (setq p2 (polar ct ang2 rd)) (command "_.dimradius" "_non" p1 "_non" p2 "") (command "_.dimarc" "_non" p1 "_non" p2 "") ) ;progn ;;; (progn ;polyline arc segment ;;;;;code (foreach l db (if (= (car l) 10) (if p1 (if bulge (progn (command "_.dimradius" "_non" p1 "_non" (cdr l) "") (command "_.dimarc" "_non" p1 "_non" (setq p1 (cdr l)) "") ; ) ) (setq p1 (cdr l)) ) (if (= (car l) 42) (setq bulge (/= (cdr l) 0.0))) ) ;;; (if (/= bulge 0.0) ;;; (progn ;;; (setq p1 (nth i ptlist)) ;;; (setq p2 (nth (+ i 1) ptlist)) ;;; ;;; (command "_.dimradius" "_non" p1 "_non" p2 "") ;;; (command "_.dimarc" "_non" p1 "_non" p2 "") ; ;;; ) ;progn ;;; ) ;if ) ;progn ) (setq i (1+ i)) ) ;repeat end ; Turn off OSNAP (setvar "osmode" 511) (princ) ) 1 Quote
GLAVCVS Posted October 25, 2025 Posted October 25, 2025 I've disabled some lines of your code that weren't working and added some new lines of code. I hope this helps. 1 Quote
maahee Posted October 27, 2025 Author Posted October 27, 2025 (edited) On 10/25/2025 at 6:06 PM, devitg said: Please upload you sample,dwg . as to test @devitg sample dwg upload for reference @GLAVCVS It may not function correctly, possibly due to the direction(clockwise or counterclockwise) of the arc or because it does not meet the point on the arc. mb.dwg Edited October 27, 2025 by maahee 1 Quote
GLAVCVS Posted October 28, 2025 Posted October 28, 2025 19 hours ago, maahee said: @devitg sample dwg upload for reference @GLAVCVS It may not function correctly, possibly due to the direction(clockwise or counterclockwise) of the arc or because it does not meet the point on the arc. mb.dwg 52.34 kB · 5 downloads The DIMRADIUS and DIMARC commands are very fickle. I've used them very little so far. But thanks to you, I'm a little more familiar with them now. So I guess I owe you a favor for that. Quote
GLAVCVS Posted October 28, 2025 Posted October 28, 2025 (edited) Yes. Part of the problem is with arcs whose initial angle (group 50 in the database) is greater than the final angle (group 51 in the database). But you also have to specify point p2 inside the arc so that it's drawn in the correct location. I had to spend a bit of time figuring this out. (defun C:bm (/ obj num i obj1 db ct rd a1 a2 p1 p2 r ptlist osmant) (setq osmant (getvar "OSMODE")) (setvar "osmode" 0) ; Turn off OSNAP (setq obj (ssget '((0 . "LWPOLYLINE,ARC")))) (setq num (sslength obj)) (setq i 0) (repeat num (setq obj1 (ssname obj i)) (setq db (entget obj1) ptlist (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) db)) ) (if (= (cdr (assoc 0 db)) "ARC") (progn (setq ct (cdr (assoc 10 db))) (setq rd (cdr (assoc 40 db))) (setq a1 (cdr (assoc 50 db)); angulo inicial del arco a2 (cdr (assoc 51 db)); angulo final del arco ) (setq a (if (> a1 a2) (+ a1 (/ (- (* 2. PI) (- a1 a2) ) 2.)) (/ (+ a1 a2) 2.))) (setq p1 (polar ct a1 rd)) (setq p2 (polar ct a (* rd 0.9))) (setq p3 (polar ct a (* rd 1.1))) (command "_.dimradius" "_non" p1 "_non" p2 "") (command "_.dimarc" "_non" p1 "_non" p3 "") ) ;progn ;;; (progn ;polyline arc segment ;;;;;code (foreach l db (if (= (car l) 10) (if p1 (if bulge (progn (command "_.dimradius" "_non" p1 "_non" (cdr l) "") (command "_.dimarc" "_non" p1 "_non" (setq p1 (cdr l)) "") ; ) ) (setq p1 (cdr l)) ) (if (= (car l) 42) (setq bulge (/= (cdr l) 0.0))) ) ) ;progn ) (setq i (1+ i)) ) ;repeat end ; Turn off OSNAP (setvar "osmode" osmant) (princ) ) Edited October 28, 2025 by GLAVCVS 1 Quote
GLAVCVS Posted October 28, 2025 Posted October 28, 2025 (edited) 40 minutes ago, GLAVCVS said: The DIMRADIUS and DIMARC commands are very fickle. I've used them very little so far. But thanks to you, I'm a little more familiar with them now. So I guess I owe you a favor for that. Seneca said: “Homines dum docent discunt.” Which, roughly, means: Learn to explain and explain to learn Edited October 28, 2025 by GLAVCVS 1 1 1 Quote
maahee Posted October 28, 2025 Author Posted October 28, 2025 (edited) 6 hours ago, GLAVCVS said: 4 hours ago, GLAVCVS said:The DIMRADIUS and DIMARC commands are very fickle. I've used them very little so far. But thanks to you, I'm a little more familiar with them now. So I guess I owe you a favor for that. @GLAVCVSthanks Edited October 28, 2025 by maahee Quote
