Associative Textbox (Lee Mac)
Dear Sir,
i trying add one more option Slot-1 rectangle with all corner rounded but result not as per image
assoctextbox
((= "SLOT-1" typ) '(0.0 0.3 0.0 0.3 0.0 0.3 0.0 0.3))
and also try
((= "SLOT-1" typ) '(0.0 0.3 0.0 0.3 0.0 0.3 0.0 0.3 0.0 0.3 0.0 0.3 0.0 0.3 0.0 0.3))
but result shown wrong
i want same result as per attached image
AssociativeTextboxV1-2.lsp
Edited by sachindkini
It will require more modification than just extending the bulge list - you also need to calculate the positions of the additional vertices.
However, I really liked your suggestion (and it's also consistent with my existing Box Text program), and so I've updated the program to Version 1.3 to incorporate a new Filleted Rectangle textbox option (you may need to refresh the page to view the new version).
Enjoy!
  • Like 2
  • Thanks 1
Enjoy!
thanks sir, its perfect
Dear sir
one question after i save the drg and again open the drg without this lisp load text or mtext not working... its possible one time used the code and this Associative text are working without upload the code everytime..
4 hours ago, sachindkini said:
Dear sir
No, the program is required to define the reactors used to update the textbox position.
  • Agree 1
  • 1 month later...
Dear Sir,
one request AssociativeTextboxV1-3 programming two modification required , Select Text or Mtext (Option required Select all text (A) or Single text pick) and all text or single text are layer name TBOX.
