sachindkini Posted October 25, 2025 Posted October 25, 2025 (edited) Dear Sir, i trying add one more option Slot-1 rectangle with all corner rounded but result not as per image assoctextbox ((= "SLOT-1" typ) '(0.0 0.3 0.0 0.3 0.0 0.3 0.0 0.3)) and also try ((= "SLOT-1" typ) '(0.0 0.3 0.0 0.3 0.0 0.3 0.0 0.3 0.0 0.3 0.0 0.3 0.0 0.3 0.0 0.3)) but result shown wrong i want same result as per attached image AssociativeTextboxV1-2.lsp Edited October 25, 2025 by sachindkini Quote
Lee Mac Posted October 25, 2025 Posted October 25, 2025 It will require more modification than just extending the bulge list - you also need to calculate the positions of the additional vertices. However, I really liked your suggestion (and it's also consistent with my existing Box Text program), and so I've updated the program to Version 1.3 to incorporate a new Filleted Rectangle textbox option (you may need to refresh the page to view the new version). Enjoy! 2 1 Quote
sachindkini Posted October 25, 2025 Author Posted October 25, 2025 40 minutes ago, Lee Mac said: It will require more modification than just extending the bulge list - you also need to calculate the positions of the additional vertices. However, I really liked your suggestion (and it's also consistent with my existing Box Text program), and so I've updated the program to Version 1.3 to incorporate a new Filleted Rectangle textbox option (you may need to refresh the page to view the new version). Enjoy! thanks sir, its perfect Quote
sachindkini Posted October 25, 2025 Author Posted October 25, 2025 Dear sir one question after i save the drg and again open the drg without this lisp load text or mtext not working... its possible one time used the code and this Associative text are working without upload the code everytime.. Quote
Lee Mac Posted October 25, 2025 Posted October 25, 2025 4 hours ago, sachindkini said: Dear sir one question after i save the drg and again open the drg without this lisp load text or mtext not working... its possible one time used the code and this Associative text are working without upload the code everytime.. No, the program is required to define the reactors used to update the textbox position. 1 Quote
SANDIP PAITAL Posted December 19, 2025 Posted December 19, 2025 On 10/26/2025 at 4:49 AM, Lee Mac said: No, the program is required to define the reactors used to update the textbox position. Dear Sir, one request AssociativeTextboxV1-3 programming two modification required , Select Text or Mtext (Option required Select all text (A) or Single text pick) and all text or single text are layer name TBOX. Quote
Alessandro Posted 3 hours ago Posted 3 hours ago Dear sir, on my autocad LT 2027, if i generate a TBOX and then i copy and paste the text (both using the command copy and using ctrl+c - ctrl+v), i don't have a copy of the tbox too. Is there a solution for this? Quote
