Gabriel Paixão Posted October 25, 2025 Posted October 25, 2025 (edited) I am trying to adapt an AutoLISP that automates the creation of fields linked to polyline areas. My goal is that based on a layer pre-established by the user, the program creates an MTEXT with a field linked to the area at its center for all closed polylines. Código original: My adapt: (defun c:A2FL ( / *error* fmt targetLayer allPolylines filteredSel idx ename obj str minPt maxPt minX minY maxX maxY centerPnt ) ;; Define the default formatting string for the Field. ;; "%lu6%qf1" generally means length units with 6 decimal places and zero suppression. ;; You can adjust this according to your needs (e.g., "%lu2%qf1" for 2 decimal places). (setq fmt "%lu6%qf1") ;; --- Local Error Handler for A2FL Command --- (defun *error* ( msg ) (LM:endundo (LM:acdoc)) ;; Ensures that the UNDO group is closed (if (not (wcmatch (strcase msg T) "*break,*cancel*,*exit*")) (princ (strcat "\nError: " msg)) ;; Displays the error message (unless it's a user interruption) ) (princ) ;; Suppresses the output of the last evaluated value ) (princ "\n--- Command: A2FL (Individual Polyline Areas by Layer) ---") ;; --- Step 1: Request Target Layer Name from User --- (setq targetLayer (getstring T "\nPlease enter the layer name for closed polylines: ")) ;; Check if the layer name was provided. (if (= "" targetLayer) (progn (princ "\nLayer name cannot be empty. Exiting 'A2FL'.") (exit) ;; Aborts command execution ) ) ;; Convert the layer name to uppercase to ensure case-insensitive comparison. (setq targetLayer (strcase targetLayer)) ;; --- Step 2: Automatically Select and Filter Closed Polylines in Target Layer --- ;; 'ssget "_X"' selects all entities in the drawing. ;; The filter '((0 . "*POLYLINE"))' restricts the initial selection to polylines only (2D, 3D and Lightweight). (setq allPolylines (ssget "_X" '((0 . "*POLYLINE")))) ;; Initialize an empty selection set to store only the filtered polylines. (setq filteredSel (ssadd)) ;; If there are polylines in the drawing to check: (if allPolylines (progn ;; Iterate over each polyline in the 'allPolylines' selection. (repeat (setq idx (sslength allPolylines)) (setq ename (ssname allPolylines (setq idx (1- idx)))) ;; Get the entity name (setq obj (vlax-ename->vla-object ename)) ;; Convert entity name to VLA object ;; Check if the polyline is in the target layer AND if it is closed. (if (and (= (strcase (vla-get-layer obj)) targetLayer) (eq :vlax-true (vla-get-closed obj)) ) (ssadd ename filteredSel) ;; Add the polyline to our filtered selection set ) ) ) ) ;; --- Step 3: Check if Any Suitable Polyline Was Found --- ;; If the 'filteredSel' selection set is empty after filtering: (if (zerop (sslength filteredSel)) (progn (princ (strcat "\nNo closed polylines found in layer '" targetLayer "'. Exiting 'A2FL'.")) (exit) ;; Aborts command execution ) ) (LM:startundo (LM:acdoc)) ;; Start an UNDO group so all operations can be easily undone. ;; --- Step 4: Process Each Filtered Polyline --- (repeat (setq idx (sslength filteredSel)) (setq ename (ssname filteredSel (setq idx (1- idx)))) ;; Get the entity name of current polyline (setq obj (vlax-ename->vla-object ename)) ;; Convert to VLA object ;; --- 4.1: Calculate the Central Point (approximate) for MText --- ;; We use the bounding box of the polyline to find an approximate center. ;; For complex or concave polylines, this point may not be "inside" the geometry, ;; but it's a simple and generally effective method for text placement. (vla-GetBoundingBox obj 'minPt 'maxPt) ;; Get the minimum and maximum corners of the bounding box (setq minX (vlax-safearray-get-element minPt 0) minY (vlax-safearray-get-element minPt 1) maxX (vlax-safearray-get-element maxPt 0) maxY (vlax-safearray-get-element maxPt 1) ) ;; Calculate the midpoint of the bounding box. (setq centerPnt (list (/ (+ minX maxX) 2.0) (/ (+ minY maxY) 2.0) 0.0)) ;; Z always 0 for 2D ;; --- 4.2: Build the Field Expression String for Current Polyline --- ;; This string is the same used for a single object in the original 'A2F' command, ;; ensuring correct field interpretation by AutoCAD. (setq str (strcat "%<\AcObjProp Object(%<_ObjId " (LM:ObjectID obj) ;; Use the ID of the *current* polyline ">%).Area \f "" fmt "">%" ) ) ;; --- 4.3: Create and Insert the MText Object in the Drawing --- ;; The MText is always added to Modelspace in this command, at the calculated center point. (vla-addmtext (vlax-get-property (LM:acdoc) 'modelspace) ;; Add to Modelspace (vlax-3D-point centerPnt) ;; Insertion point (the centroid) 0.0 ;; Text height (uses default height or annotative scale) str ;; The generated field string ) ) (LM:endundo (LM:acdoc)) ;; End the UNDO group. (princ (strcat "\nCommand 'A2FL' completed. " (itoa (sslength filteredSel)) " area fields inserted.")) (princ) ;; Suppress the output of the last evaluated value in the command line. ) ;; The auxiliary functions (LM:ObjectID, LM:getcell, LM:startundo, LM:endundo, LM:acdoc) ;; and COM loading (vl-load-com) (princ) are assumed to be already defined ;; and available in your original 'Areas2FieldV1-3.txt' file. ;; Do not redefine them here if they are already in the same file. Edited October 26, 2025 by CADTutor Add code block Quote
Steven P Posted October 26, 2025 Posted October 26, 2025 If it was me I would allow the user to select an entity on the layer rather than typing it in, or use something like BigAls multi getvals to select the layer from a list - saves typing errors. You can add to filters in the selection set: (setq allPolylines (ssget "_X" (list (0 . "*POLYLINE")(cons 8 MyLayerName)))) Note here that list is used if you want any of the filters to be programmatically. 'cons' used to construct the list and MyLayerName is a variable you might want to work out earlier in the LISP. Lee Mac has a very good explanation on his website for ssget. You can loop through your selection set and perhaps this snippet will help: ;;https://www.cadtutor.net/forum/topic/66091-centre-of-hatch/ ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun c:CtrCoo (/ findctr a apt) ;;Center point of a hatch or a rectangle (defun findctr (en / pt) (command "_.Zoom" "_Object" en "") (setq pt (getvar 'viewctr)) (command "_.Zoom" "_Previous") pt ) (setq a (car (entsel "Select Rectangle: : ")) apt (findctr a) ) (command "_Text" "_Justify" "_MC" apt 0.1 0 apt) (princ) ) Copy FindCtr and use that to get the centre point of each object, using that as the insert point for the mtext. Maybe this will help you along? Quote
BIGAL Posted October 26, 2025 Posted October 26, 2025 Also this as mentioned. (setq ent (entget (car (entsel "\nPick an object for layer name ")))) (setq MyLayerName (cdr (assoc 8 ent))) (setq allPolylines (ssget "_X" (list (0 . "*POLYLINE")(cons 8 MyLayerName)))) 1 Quote
