Hi, Is there a Lisp routine which can move all objects within a selected polyline to a layer called "exist" and all objects outside that same polyline to a layer called "site" ?? ignoring all frozen or OFF layers ?? Regards.
If you want to have a go, look at Selection Sets to select everything within the polyline (see Lee Mac Selection sets page - it is rather good - ssget), window polygon or crossing polygon
Do 2 selection sets - one for everything "_X" and one for Crossing Polygon, I think Lee Mac has a routine there to remove one selection set from another.
This gives you 2 sets of entities to work with
Loads of LISPs out there to change layers.
Have a go, it is easier than you might think
Try this:
(defun c:chglyobjpl (/ acdoc p_list p_coord sset ent obj newLayerName i)
  (vl-load-com)
  (setq acdoc (vla-get-ActiveDocument (vlax-get-acad-object)))
;;;;;;;;;;;https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/selection-set-using-existing-polygon/td-p/11307274
;;;;;;;;;;;calderg1000 msg-7
  (setq p_list (entget (car (entsel "\nSelect the LwPolyline: "))))
  (if (setq
        p_coord (mapcar 'cdr
                        (vl-remove-if-not '(lambda (x) (= (car x) 10)) p_list)
                );;end setq p_coord
      );;end if condition
    (sssetfirst nil (setq sset (ssget "_wp" p_coord)))
;;;;;;;;;;;;;;;;;;;;;;;;;;;;Select Objects In polygon;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
;;;;;;;;;;;;;;;;;;;;;;;;;;;;Change Objects Layer;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
  (if sset
      (setq newLayerName "exist") ;;(getstring T "\nEnter new layer name: "))
      (repeat (setq i (sslength sset))
        (setq i (1- i))
        (setq ent (ssname sset i))
        (setq obj (vlax-ename->vla-object ent))
        (vla-put-Layer obj newLayerName)
      );;repeat
      (vla-Regen acdoc acAllViewports)
      (sssetfirst nil nil)
    );;progn
    (princ "\nNo objects found in the drawing.")
  );;if
);;end defun
Edited by aridzv
Thanks ...
but.....
on running the program, its saying that "no objects found in the drawing" and the program closes
see new code.
make sure the layers names are correct.
(defun c:chglyobjpl (/ acdoc p_list p_coord sset ent obj newLayerName newLayerName1 i)
  (vl-load-com)
  (princ "\nSelect All Objects To Proccess")
  (setq ssall (ssget))
  (setq p_list (entget (car (entsel "\nSelect the Polyline Boundery For ''exist'' Layer: "))))
  (setq i 0)
;;;;;;;;;;;;;;;;;;;;;;;;;;;Change Objects To site Layer;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(if ssall
    (setq newLayerName1 "site");;(getstring T "\nEnter new layer name: "))
      (repeat (setq i (sslength ssall))
        (setq i (1- i))
        (setq ent (ssname ssall i))
        (vla-put-Layer obj newLayerName1)
      );;repeat
    );;progn
  );;if
  (setq ent nil)
  (setq obj nil)
  (setq i 0)
  (if (setq
                );;end setq p_coord
      );;end if condition
  (if sset
      (setq newLayerName "exist");;(getstring T "\nEnter new layer name: "))
        (setq i (1- i))
      );;repeat
    );;progn
  );;if
;;;;;;;;;;;;;;;;;;;;;;;;;;;;Change Objects To exist Layer;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
);;end defun
Edited by aridzv
My $0.05 does not check for off or frozen layers.
(defun c:wow ( / ent co-ord ss)
(if (tblsearch "layer" "Site")
  (command "-layer" "Make" "Site" "c" 1 "" "")
(if (tblsearch "layer" "Exist")
  (command "-layer" "Make" "Exist" "c" 2 "" "")
(command "chprop" "all" "" "la" "Site" "")
(setq ent (car (entsel "\nPick the pline ")))
(setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget ent))))
(setq ss (ssget "WP" Co-ord))
(command "chprop" ss "" "LA" "Exist" "")
(c:wow)
Hi,  many thanks for your help Aridzv and BigAl,
But, all entities are being converted to layer "site". The ones inside the pline are not being moved to layer "exist"
I'm attaching the drawing on which I am testing.
surveytest.dwg
