Hi all,
I get a DWG with multiple layers with lines and such.
Now... each line has Object Data linked to it.
I need to make a export to GIS, where each layer is its own layer in QGIS.
When i make a export to SHP or GML, and load it in QGIS, all layer informatie is gone and is put on only GIS layer.
What is the most effective way to export AutoCAD layers to GIS layers?
I just use the QGIS Import for drawings from AutoCAD and I get the layers.
I think for surfaces, QGIS needs DEM, IIRC _SurfaceExportToDem is in Civil 3D.
Maybe in QGIS Import the SHP or just the .dwg and Go to "Layer" then  "Add Layer" then "Add Vector Layer".
My QGIS is at home, so I think those steps are close.
