Solidworks VBA for renaming components in an assembly
This macro works in Solidworks 2024. Would someone please help me to get it working properly for 2025?
See attached file.
Thanks.
jn_2.txt
What is the error you get?
SolidWorks changed a few VBA commands from 2024 to 2025, you'll probably get better results on a SolidWorks/Dassault Systems forum.
A quick search on SolidWorks VBA changes between 2024 and 2025 might help.
You can wrap the inputbox with ucase(trim(  or even add things infront like i did with description eliminating lines of code.
old
    ' --- Ask user if they want to Add or Remove description ---
    action = InputBox("Type 'A' to Add description or 'R' to Remove description:", "Action Choice", "A")
    action = UCase(Trim(action))
    If action <> "A" And action <> "R" Then MsgBox "Invalid input.": Exit Sub
    ' --- Optional prefix ---
    prefix = ""
    Dim userInput As String
    userInput = InputBox("Enter component location prefix: T for Top, B for Bottom, leave blank for none:", "Prefix Option")
    userInput = UCase(Trim(userInput))
    If userInput = "T" Then prefix = "Top_"
    If userInput = "B" Then prefix = "Bot_"
    ' --- Optional description (only if adding) ---
    If action = "A" Then
        description = InputBox("Enter description to append (leave blank for none):", "Optional Description")
        description = Trim(description)
        If description <> "" Then description = "_" & description
            CopyToClipboardAPI (description)
            MsgBox "Description '" & description & "' copied to clipboard."
        End If
    End If
New
    action = UCase(Trim(InputBox("Type 'A' to Add description or 'R' to Remove description:", "Action Choice", "A")))
    userInput = UCase(Trim(InputBox("Enter component location prefix: T for Top, B for Bottom, leave blank for none:", "Prefix Option")))
    Select Case True
      Case userInput = "T"
        prefix = "Top_"
      Case userInput = "B"
        prefix = "Bot_"
      Case Else
        prefix = ""
    End Select
      description = "_" & Trim(InputBox("Enter description to append (leave blank for none):", "Optional Description"))
      If description <> "_" Then ;old code would still allow "_" to be copied to clipboard this skips and should prob exit sub if description is only "_" ?
      Else
        MsgBox "Description is Blank " & vbCrLf & " Exiting Command"
        Exit Sub
      End If
    End If
Didn't run past fso. please describe what your running into.
Edited by mhupp
I only dabble in VBA but have these changed "kernel32" "user32" or maybe where you point to them, have had some VBA do this that refers to wrong library used.
Also noticed the CopyToClipboardAPI can be replaced with three lines if you add a reference to Microsoft Forms 2.0 Object Library
Dim obj As New MSForms.DataObject
  obj.SetText description
  obj.PutInClipboard
Else
Edited by mhupp
Yea with the resent forced update in windows 11 some things went funky for people.
Edited by mhupp
