Cross Section area and Its calculation
Hello,
I need to find net cross section area of river after proposing design section. Also i need a detailed calculation (like 1/2 x length x width) written below every section. Is it possible using LISP command??
Have you got a sample drawing which might show  bit more detail? should be possible though - simplest if you have the cross section drawn out is hatch, use properties to get the hatch area. I suspect it will be more complex than that
Your profile does not show what CAD software you are using.
Yes, you need to post a drawing, preferably showing a before and after.
A quick way to get true areas where you have Horizontal and vertical scales is to block all the cross sections and then reset the Hor & ver scale. Did you google this has been asked many times before.
Of course the simplest is use a 3rd party Civil software add on they have volumes all built in. Will pay for its self very quickly.
