Align the extension lines to the short line of each selected size
Hello everyone.
You need to select several sizes and align the extension lines to the short line of each selected size.
Maybe there is such a program?
Edited by Nikon
  • Nikon changed the title to Align the extension lines to the short line of each selected size
I don't think we've understood your question yet (at least I haven't).
You might need to elaborate a bit and add some more images.
Edited by GLAVCVS
I'm guessing they have a drawing and want all the long blue dim extension lines to be shortened to where the dimension is. but the top blue one looks like its pulling from the right and left like the dimension itself is inside the feature its measuring. were the bottom red is only pulling from the right.
Sometimes the extension lines of associative dimensions are stretched (for example, to the origin of coordinates ) when inserted into another drawing.
Now I've found a way to disable size associativity, but I don't really like it. I only find out that the dimensions have lost their connection with the object when I insert them into another drawing (or turn on the annotation monitor).
So I thought it would be possible to align the extension lines to a smaller extension line.
Maybe there is a better way...
; disable associativity of only selected sizes
(defun c:DimAssOf ( / ss)
  (vl-load-com)
  (prompt "\nSelect DIMENSION to disable associativity: ")
  (setq ss (ssget '((0 . "DIMENSION"))))
  (if ss
      (command "_.DIMDISASSOCIATE" ss "")
      (prompt
        (strcat
          "\nDone: associativity is disabled for "
          (itoa (sslength ss))
          " dimensions."
extension lines.dwg
Edited by Nikon
