I am going around in circle and not sure why. I have a Mtext  a simple 3 line Mtext
(setq txt "Abcdef\\Pghijk\\Plmnop")
desired text for Excel a multi line cell
"Abcdef\nghijk\nlmnop"
thought something like this should work. Tried all sorts of combinations. Note a dbl \\ will leave the P behind but get multi lines.
(setq txt  (vl-string-translate "\\P" "\n" txt))
I have all the other code done putting all the object values int Excel cells. Think Dataextract.
Edited by BIGAL
(defun c:t1 ( / txt1 delimiter txt2 )
  (setq txt1 "Abcdef\\Pghijk\\Plmnop")
  (setq delimiter "\\P")
  (setq txt2 (pjk-Strparse txt1 delimiter))
  (princ (strcat "\ntxt2 = " (vl-prin1-to-string txt2)))
;;; https://www.cadtutor.net/forum/topic/95913-replace-p-in-a-variable/
  Function Name: (pjk-StrParse)
  Arguments:
     str = String; String to process
     del = String; Delimiter to separate the string
  Usage: (pjk-StrParse <string> <delimter>)
  Returns: List; A list of strings
  Description:
     Separates a string into a list of strings using a
     specified delimiter string; uses recursion.
(defun pjk-StrParse (str del / pos)
  (if (and str del)
     (if (setq pos (vl-string-search del str))
       (cons (substr str 1 pos) (pjk-StrParse (substr str (+ pos 1 (strlen del))) del))
       (list str)
) ;; End Function (pjk-StrParse)
You can build a lisp function in Python that will explode the MText into fragments
@Ap.Command()
def doit():
    try:
        ps, id, pnt = Ed.Editor.entSel("\nSelect: ", Db.MText.desc())
        mt = Db.MText(id)
        frags = mt.getFragments()
        val = ""
        for frag in frags:
            val += ' '
            val += frag[Db.MTextFragmentType.kTextValue]
        print(frags)
        print(val)
    except Exception:
        print(traceback.format_exc())
[PyGe.Point3d(18.25565516926225,16.52816695203355,0.00000000000000), PyGe.Vector3d(0.00000000000000,0.00000000000000,1.00000000000000), PyGe.Vector3d(1.00000000000000,0.00000000000000,0.00000000000000), 'Hello', None, None, PyGe.Point2d(0.63669849931787,0.20327421555252), 0.2, 1.0, 0.0, 1.0, <PyDb.EntityColor object at 0x000001AD0C1D0F90>, 0, 0, 0, 0, 0, [PyGe.Point3d(0.00000000000000,0.00000000000000,0.00000000000000), PyGe.Point3d(0.00000000000000,0.00000000000000,0.00000000000000)], [PyGe.Point3d(0.00000000000000,0.00000000000000,0.00000000000000), PyGe.Point3d(0.00000000000000,0.00000000000000,0.00000000000000)], [PyGe.Point3d(0.00000000000000,0.00000000000000,0.00000000000000), PyGe.Point3d(0.00000000000000,0.00000000000000,0.00000000000000)], 'Arial', False, False]
[PyGe.Point3d(19.29427328818596,15.86150028536689,0.00000000000000), PyGe.Vector3d(0.00000000000000,0.00000000000000,1.00000000000000), PyGe.Vector3d(1.00000000000000,0.00000000000000,0.00000000000000), 'World', None, None, PyGe.Point2d(0.72960436562074,0.20327421555252), 0.2, 1.0, 0.0, 1.0, <PyDb.EntityColor object at 0x000001AD0C1D1770>, 0, 0, 0, 0, 0, [PyGe.Point3d(0.00000000000000,0.00000000000000,0.00000000000000), PyGe.Point3d(0.00000000000000,0.00000000000000,0.00000000000000)], [PyGe.Point3d(0.00000000000000,0.00000000000000,0.00000000000000), PyGe.Point3d(0.00000000000000,0.00000000000000,0.00000000000000)], [PyGe.Point3d(0.00000000000000,0.00000000000000,0.00000000000000), PyGe.Point3d(0.00000000000000,0.00000000000000,0.00000000000000)], 'Arial', False, False]
Hello World
Per the documentation, (vl-string-translate) replaces by character, not by string. Hence, for the arguments you have specified, the backslash ("\\") will be replaced by the newline character ("\n") and the "P" does not have a replacement character.
Instead, since you're looking to substitute one string for another, you should use the (vl-string-subst) function (in a loop so as to replace all occurrences).
I have written a String Subst wrapper which you could call in the following way:
(LM:stringsubst "\n" "\\P" "Abcdef\\Pghijk\\Plmnop")
Thanks everyone, the answer sometimes is just looking at you and waving back. Need to double check help in future.
(while (wcmatch txt "*\P*")
  (setq txt  (vl-string-subst "\n" "\\P" txt 1))
Edited by BIGAL
You're missing the double backslash ("*\\P*")
Also, note that the use of vl-string-subst with a constant starting position and wcmatch to test the content is dangerous in general as this will result in an infinite loop if the replacement string contains the find string, e.g. consider replacing "new" with "knew" - your code would loop indefinitely.
Thanks Lee yes during testing had a stuck loop a few times had to crash out CAD. Will use the full defun rather than the short version.
