Hello
I created these functions, but neither of them can change the layer names to uppercase or lowercase. The strange thing is that this routine has been used for a long time.
FlagCaixa= 0 (abcde.....)
FlagCaixa= 1 (ABCDE.....)
;sample 01
(defun AlteraCaixaNomesLayers ( FlagCaixa / CollLayDwg ObjVlaLay TxtNomLay LstLayDwgNew )
    (setq CollLayDwg (vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object))))
    (vlax-for ObjVlaLay CollLayDwg
        (setq TxtNomLay (vla-get-name ObjVlaLay))
        (if (and (/= TxtNomLay "0") (/= TxtNomLay "Defpoints"))
                (if (= FlagCaixa 0)
                        (vla-put-name ObjVlaLay (strcase TxtNomLay))
                         (vla-put-name ObjVlaLay (strcase TxtNomLay T))
;sample 02
(defun AlteraCaixaNomesLayers ( FlagCaixa / TxtNomLay LstLayDwgNew NomObjLayDwg LstNomObjLayDwg )
    (setq LstNomLayersDwg (GeraListaNomeLayersDoDesenho))
    (foreach TxtNomLay LstNomLayersDwg
        (if (= FlagCaixa 0)
                (vl-cmdf "rename" "la" TxtNomLay (strcase TxtNomLay))
                 (vl-cmdf "rename" "la" TxtNomLay (strcase TxtNomLay T))
    (vl-cmdf "regen")
(defun GeraListaNomeLayersDoDesenho ( / for-item LstNomeLayers Layer_name )
    (vlax-for for-item (vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object)))
        (if (and (vlax-property-available-p for-item 'Name) (/= (vla-get-Name for-item) "0")
                         (vlax-property-available-p for-item 'Freeze) (= (vla-get-freeze for-item) :vlax-false)
                         (vlax-property-available-p for-item 'LayerOn) (= (vla-get-layerOn for-item) :vlax-true)
                         (vlax-property-available-p for-item 'Lock) (= (vla-get-lock for-item) :vlax-false)
                         (not (member (setq Layer_name (vla-get-Name for-item)) LstNomeLayers))
                (setq LstNomeLayers (cons Layer_name LstNomeLayers))
    (vl-sort LstNomeLayers '<)
Thank you if anyone can help me.
I think that the only way to do reliably is to look at every character in the string, so A-Z = 65-90 and a-z =97-122 so using (chr x) can rebuild string.
; https://www.cadtutor.net/forum/topic/98847-problem-renaming-layers/
; Convert layers to upper or lower case-insensitive
; By AlanH Nov 2025
(defun AlteraCaixaNomesLayers ( FlagCaixa / CollLayDwg ObjVlaLay TxtNomLay char nchar str)
(if (or (= TxtNomLay "0") (= TxtNomLay "Defpoints"))
(if (= FlagCaixa 1)
  (setq x 1)
  (setq str "")
  (repeat (strlen TxtNomLay)
    (setq char (ascii (substr txtnomlay x 1)))
    (cond
	((and  (> char 64)(< char 91))
    (setq nchar (chr (+ char 32)))
    (setq str (strcat str nchar))
	((or  (< char 65)(> char 90))
	  (setq nchar (chr char))
    (setq x (1+ x))
  (vla-put-name ObjVlaLay str)
(AlteraCaixaNomesLayers 0)
Use code tags when posing. The stuff you posted works for me have you upgraded recently? are the layers locked from an xref? maybe (vl-load-com) hasn't been called yet and you seeing any errors when the code runs?
Or might just be a typo in your function name?
FlagCaixa= anything else (ABCDE.....)
renamed to use an a so its "Names"
(defun AlteraCaixaNamesLayers (FlagCaixa / doc layers lay old new)
  (vl-load-com)
  (setq layers (vla-get-Layers (setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))))
  (vla-startundomark doc)
  (vlax-for lay layers
    (setq old (vla-get-Name lay))
    (if (not (member old '("0" "DEFPOINTS")))
        (if (= FlagCaixa 0)
          ;dont need progn if you only have two lines of code.
          (vla-put-name lay (strcase old))    ;if true run this line
          (vla-put-name lay (strcase old T))  ;if false run this line
  (vla-EndUndoMark doc)
if you only want 0 or 1 as the only two options use cond. also allows you to have more options in the future if you want.
  (vl-load-com)
      (cond
        ((= FlagCaixa 0) (vla-put-name lay (strcase old)))
        ((= FlagCaixa 1) (vla-put-name lay (strcase old T)))
nice tutorial on cond here also cond's don't need (progn if they have multiple lines of code.
Gentlemen,
I must try to interpret each of your generous examples. These are very involved lines of code to this (older) novice.
I will study CHAR as it appears to be key to text case definitions.
Clint
P.S.: Have any here heard of, used or now use the tried and true 20+ year old LAYECREATOR.LSP  program?
It would be best to start a new post asking questions about making layers.
Me like many others have defuns to make layers on the fly. If you describe what your trying to do I expect a quick response.
Admin please move post.
Hi BIGAL,
Your point is well received!
Best regards,
Clint Hill
