Hi all
Could someone help me with this lisp code, please.
What I would like :
1) PUBLISH first as pdf ( with existing settings used) and Pause until PUBLISH finished.
2) Delete all Paper spaces and create Default Layout1
3) Purge drawing twice
3) Save as DXF Binary 2007 file.
So far I am getting results i need to delete all paper spaces and create default layout1,  Purge and saving as dxf Binary 2007 file automatically.
Ideally I just want user friendly lisp code to publish pdf on desktop and save  smallest file possible as dxf on desktop.
(defun c:CleanAndSaveDXF ( / doc lays desktop dwgname fullpath Layout1Obj oldCmdecho )
  ;; Save and turn off command echoing
  (setq oldCmdecho (getvar "CMDECHO"))
  (setvar "CMDECHO" 0)
  ;; 1) Keep/create exactly one "Layout1", delete everything else
  (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))
        lays (vla-get-Layouts doc)
        Layout1Obj nil)
  (vlax-for lay lays
    (cond
      ( (= (vla-get-Name lay) "Model") )
      ( (= (strcase (vla-get-Name lay)) "LAYOUT1") (setq Layout1Obj lay) )
      ( t (vl-catch-all-apply 'vla-Delete (list lay)) )
  (or Layout1Obj (vla-Add lays "Layout1"))
  (vla-put-ActiveLayout doc (vla-Item lays "Model"))
  ;; 2) Ultra-purge
  (repeat 6 (command "-PURGE" "All" "*" "N"))
  (command "-PURGE" "Regapps" "*" "N")
  (command "-PURGE" "Z" "*" "N")
  (command "-PURGE" "E" "*" "N")
  ;; 3) Build exact filename (same base name, pure .dxf)
  (setq desktop (strcat (getenv "USERPROFILE") "\\Desktop\\"))
  (setq dwgname (vl-filename-base (getvar "DWGNAME")))
  (if (or (null dwgname) (= dwgname "")) (setq dwgname "Drawing"))
  (setq fullpath (strcat desktop dwgname ".dxf"))
  ;; 4) Remove any existing file (including .dxf.dwg garbage)
  (foreach ext (list fullpath (strcat fullpath ".dwg"))
    (if (findfile ext) (vl-file-delete ext))
  ;; 5) Export as BINARY 2007 DXF
  (command "._EXPORT" fullpath "2007" "B")
  ;; 6) One final purge
  (repeat 2 (command "-PURGE" "All" "*" "N"))
  ;; === NEW: Run the whole thing ONE MORE TIME automatically ===
  (if (= (getvar "USERI1") 0)           ; first run  → marker = 0
      (setvar "USERI1" 1)                 ; mark that we are now on the second run
      (princ "\n--- Running second (final) pass for maximum cleanliness ---\n")
      (c:CleanAndSaveDXF)                ; ← recursive call – runs again immediately
      (setvar "USERI1" 0)                 ; reset marker for next time you use the command
  ;; Restore original CMDECHO (only on the very last exit)
  (setvar "CMDECHO" oldCmdecho)
  (princ (strcat "\nClean BINARY DXF (2007) created → " fullpath "\n"))
Edited by pyou
Have a look at (setq lays (layoutlist)) there is no Model in the list created saves a few if and buts. Can use also (setvar 'ctab "Model") so no Doc required.
  • Agree 1
How do incorporate publish pdf  with present default settings? Basically just (_publish " ") and ENTER, but  it keeps asking me for  more information , need just pdf export with present default settings as it is.
maybe just something simple as :
(setvar "filedia" 0)
(command ".-plot" "No" "" "" "" (strcat (getvar 'dwgprefix) (getvar 'ctab) ".pdf") "No" "Yes")
(setvar "filedia" 1)
Like @rlx this is a hard coded plot pdf using preset values, our dwg's used layouts one title block. the code is hard coded for a A1 sheet plotted as a A3 size. We just walked through the layouts and plotted. So does not matter what current plot settings are as they are ignored. We had multiple devices PDF, A1, A3 Color, A3 B-W. So code for each.
(setvar "textfill" 1)
(setvar "fillmode" 1)
    (COMMAND "-PLOT"  "Y"  "" "Plot To PDF"
	       "Iso full bleed A3 (420.00 x 297.00 MM)" "m" "LANDSCAPE"  "N"   "W"  "-6,-6" "807,560" "1=2"  "C"
	       "y" "Acad.ctb" "Y"	"n" "n" "n" pdfName "N" "y"
