alp22 Posted December 3, 2025 Posted December 3, 2025 I need a lisp command that will allow me to gather coordinates from multiple places and then put that information into a table Quote
jonathann3891 Posted December 3, 2025 Posted December 3, 2025 This might be much easier using a simple block and utilizing data extraction on said block. Quote
mhupp Posted December 3, 2025 Posted December 3, 2025 Need a little more info than "gather coordinates from multiple places" how do you want to do that? and from what places? are these entity's in the drawing or txt/cvs files? like Jonathann3891 suggestion here is one lee made for polylines https://www.lee-mac.com/polyinfo.html Attach some sample drawings or files. 1 Quote
Steven P Posted December 3, 2025 Posted December 3, 2025 As above, need more information as where the data is coming from and how you want the LISP to run. The one I use "EOLA", "EOLB" (End "A" of line and End "B" of line) I run by pick line, pick text to replace - having created the template before hand (well, LISP does that). Might be you want the coordinates of circles and the table to be created in the order you select them, or ordered left to right, right to left, so could do with a bit more to work with. Quote
BIGAL Posted December 3, 2025 Posted December 3, 2025 Might as well join the party, yes easy task, but missing. is co-ords to be labelled in some way so know which co-ords match which point.. Need you to post a proper dwg with desired table all set up, text height, column widths and so on. Quote
