There are several fields with 1 decimal place.
Is there a way to convert selected fields with 1 decimal
place into fields with 2 decimal places without losing the connection of fields with objects?
The field is 1 decimal place
%<\AcExpr (3.1416*%<\_FldPtr 1317270971888>%^2/4*0.0785*%<\_FldPtr 1317270971632>%*%<\_FldPtr 1317270971472>%/10000) \f "%lu2%pr1">%
The field is 2 decimal places
%<\AcExpr (3.1416*%<\_FldPtr 1317157078864>%^2/4*0.0785*%<\_FldPtr 1317157078096>%/10000) \f "%lu2%pr2">%
fields.dwg
"pr2" is precision - here 2 places, "pr1" at the end of the first expression is 1 decimal place
I have dozens of fields that need to be adjusted for accuracy.
It will take a long time to edit each field...😉
If you can identify where the field strings are then you could update them, you can look for say "AcExpr" in the string then replace pr1. Maybe use Bedit and Attsync to update blocks. Similar for Mtext.
So where are they ? Provide a sample dwg, You should be able to do something by now look at (Vlax-get obj 'textstring)
Edited by BIGAL
The fields are in the text, not in the block.
The sample fields.dwg is attached in the first post.
The problem is that you need to change the accuracy of several fields at the same time.
