There are several fields with 1 decimal place.
Is there a way to convert selected fields with 1 decimal
place into fields with 2 decimal places without losing the connection of fields with objects?
The field is 1 decimal place
%<\AcExpr (3.1416*%<\_FldPtr 1317270971888>%^2/4*0.0785*%<\_FldPtr 1317270971632>%*%<\_FldPtr 1317270971472>%/10000) \f "%lu2%pr1">%
The field is 2 decimal places
%<\AcExpr (3.1416*%<\_FldPtr 1317157078864>%^2/4*0.0785*%<\_FldPtr 1317157078096>%/10000) \f "%lu2%pr2">%
fields.dwg
Edited by Nikon
"pr2" is precision - here 2 places, "pr1" at the end of the first expression is 1 decimal place
  • Agree 1
I have dozens of fields that need to be changed the precision.
It will take a long time to edit each field...😉
Edited by Nikon
If you can identify where the field strings are then you could update them, you can look for say "AcExpr" in the string then replace pr1. Maybe use Bedit and Attsync to update blocks. Similar for Mtext.
So where are they ? Provide a sample dwg, You should be able to do something by now look at (Vlax-get obj 'textstring)
Edited by BIGAL
The fields are in the text, not in the block.
The sample fields.dwg is attached in the first post.
The problem is that you need to change the accuracy of several fields at the same time.
You can try this.
(vl-load-com)
(defun c:change_prec ( / ss AcDoc Space n ename Obj value_string nbs tmp_nbs)
  (princ "\nSelect MText.")
  (while
    (null
      (setq ss
        (ssget
          (list
            '(0 . "*TEXT")
            (cons 67 (if (eq (getvar "CVPORT") 1) 1 0))
            (cons 410 (if (eq (getvar "CVPORT") 1) (getvar "CTAB") "Model"))
    (princ "\nAren't MText or Text!")
  (setq
    AcDoc (vla-get-ActiveDocument (vlax-get-acad-object))
    Space
    (if (= 1 (getvar "CVPORT"))
      (vla-get-PaperSpace AcDoc)
      (vla-get-ModelSpace AcDoc)
  (vla-startundomark AcDoc)
  (repeat (setq n (sslength ss))
    (setq
      ename (ssname ss (setq n (1- n)))
      Obj (vlax-ename->vla-object ename)
    (setq value_string (vla-FieldCode Obj) nbs 0)
    (cond
      ((eq (substr (vla-FieldCode Obj) 1 3) "%<\\")
        (while nbs
          (if (setq nbs (vl-string-search "%pr2" value_string (setq tmp_nbs nbs)))
            (setq
              value_string (vl-string-subst "%pr1" "%pr2" value_string tmp_nbs)
              nbs (1+ nbs)
        (vlax-put Obj 'TextString value_string)
  (vla-endundomark AcDoc)
  (prin1)
  • Like 2
8 hours ago, Tsuky said:
You can try this.
(vl-load-com)
@Tsuky thank you very much, your code changes the precision of the fields from 2 to 1.
I replaced 2 lines in the code to change the precision from 1 to 2.
            (setq
(if (setq nbs (vl-string-search "%pr1" value_string (setq tmp_nbs nbs)))
            (setq
              value_string (vl-string-subst "%pr2" "%pr1" value_string tmp_nbs)
You've been very helpful!   🎇
Edited by Nikon
  • Agree 1
  • Nikon changed the title to Changing the precision of fields
2 hours ago, Tsuky said:
You can try this.
(vl-load-com)
I have made several versions of the change_prec.lsp code.
Maybe it will be useful to someone.
Changing the precision of several fields
change_prec_1-2.lsp === changing the precision of the fields from 1 to 2
change_prec_1-3.lsp === changing the precision of the fields from 1 to 3
change_prec_2-1.lsp === changing the precision of the fields from 2 to 1
change_prec_2-3.lsp === changing the precision of the fields from 2 to 3
change_prec_3-1.lsp === changing the precision of the fields from 3 to 1
change_prec_3-2.lsp === changing the precision of the fields from 3 to 2
change_prec_fields.lsp
  • Agree 1
Added a little on the front end to wrap it all in one command with user input options. Should display something like this
Change_Prec or CP
Enter "C" for Custom Values
Choose Percision From:To : [1:2 1:3 2:1 2:3 3:1 3:2]: 3:2
Changing Select MText Precision From [3] to [2]
Change_Prec or CP
Choose Percision From:To : [1:2 1:3 2:1 2:3 3:1 3:2]: C
Existing Precision: 1
Precision Change to: 4
Changing Select MText Precision From [1] to [4]
Change_Prec 2 1
Changing Select MText Precision From [2] to [1]
-Edit
Updated it so you can just type "Change_Prec 3 2"  and skip all that and just start asking you to make a selection.
Edited by mhupp
  • Thanks 1
Thanks, that's a good idea, but this code doesn't work for me.
Edited by Nikon
I'll have to debug it when i get home just typed it up in note pad.
-Edit
Well if i took two seconds to look at the code. was using integers and needs to be strings. because Tusky is calling vl-string-subst. if its still bugged ill fix it tonight.
Edited by mhupp
  • Thanks 1
With (initget) and (getkword) for choice precision...
(vl-load-com)
(defun c:change_prec ( / ss AcDoc Space prec_source ktarget n ename Obj value_string nbs tmp_nbs)
  (while
    (null
      (setq ss
        (ssget
          (list
            '(0 . "*TEXT")
  (setq
    Space
  (initget 1 "0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Current")
  (setq ktarget (getkword "\nPrecision of target number [0/1/2/3/4/5/6/7/8/9/10/11/12/13/14/15/16/Current]?: "))
    (setq
    (cond
      ((vl-string-search "%<\\" value_string nbs)
        (while nbs
          (if (setq nbs (vl-string-search "%pr" value_string (setq tmp_nbs nbs)))
            (setq
              prec_source (itoa (atoi (substr value_string (+ nbs 4) 2)))
              value_string
              (vl-string-subst
                (if (eq ktarget "Current")
                  (strcat "%pr" (itoa (getvar "LUPREC")))
                  (strcat "%pr" ktarget)
                (strcat "%pr" prec_source)
                value_string
                tmp_nbs
              nbs (1+ nbs)
  (prin1)
Edited by Tsuky
Introduces current accuracy and search in mtext
  • Agree 1
  • Thanks 1
(vl-load-com)
(defun c:change_prec ( / ss AcDoc Space ksource ktarget n ename Obj value_string nbs tmp_nbs)
For some reason, the code only works in Text. When selecting MText, the precision does not change...
Is it possible to assign the same precision or current precision to fields with different precision?
Edited by Nikon
I've modified my latest code to introduce current precision and search in the Mtext
  • Thanks 1
K updated my code as well. tho this seems to not work well with BricsCAD. moved the vlax-put to only update when the if statment is true.
change_prec_fields_update.lsp
  • Thanks 1
@mhupp this may be useful, it captures command errors so after loading your lisp. You type say p2-3 on command line. Can do say p1-2, Pr3-2, prec1-0 and so on.
; test trap a command used as variable input
; BY Alan H 2019
; now 2025
(   (lambda nil
        (vl-load-com)
        (foreach obj (cdar (vlr-reactors :vlr-command-reactor))
            (if (= "fillet-reactor" (vlr-data obj))
                (vlr-remove obj)
        (vlr-command-reactor "fillet-reactor" '((:vlr-unknowncommand . fillet-reactor-callback)))
(defun fillet-reactor-callback ( obj com )
(setq com (car com))
(alert com)
; do the split com into
; (Change_Prec X X))
) ; defun
(or fillet-reactor-acdoc
    (setq fillet-reactor-acdoc (vla-get-activedocument (vlax-get-acad-object)))
Thinking more maybe only check p12, prec10
Edited by BIGAL
  • Agree 1
Thanks, the code works perfectly with the Texts, I didn't even think it was possible. 👍
But nothing works with the MText.
I choose the MText, I choose "Precision of target number", but the precision does not change.
If the code is applied to the MText, then after that the MText cannot be copied and pasted into another drawing.
change_prec_fields.dwg
Edited by Nikon
Thanks, the code works with the Texts. I changed the selection line a bit.
(setq choice (getkword "\nChoose Percision From:To : [1:2/1:3/2:1/2:3/3:1/3:2]: "))
