leonucadom Posted yesterday at 08:59 PM Posted yesterday at 08:59 PM hello all: I use this routine to lower all selected objects to z0 The problem is that it also affects 3D solids if I have them. Is there a way to modify the code excluding 3D solids from the selection? _move;_all;;0,0,0;0,0,1e99;_move;_p;;0,0,0;0,0,-1e99 I appreciate the comments and hope they can help me. Quote
BIGAL Posted 23 hours ago Posted 23 hours ago (edited) It could be as simple as changing "all" to "ss", where ss is a selection set. I am no expert on setting the exclude objects in a selection set. try this not really tested. (setq ss (ssget "_X" '((-4 . "<NOT") (0 . "3DSOLID") (-4 . "NOT>")))) or _move;(setq ss (ssget "_X" '((-4 . "<NOT") (0 . "3DSOLID") (-4 . "NOT>"))));;0,0,0;0,0,1e99;_move;ss;;0,0,0;0,0,-1e99 Edited 22 hours ago by BIGAL 1 1 Quote
SLW210 Posted 9 hours ago Posted 9 hours ago Here is the button macro for selected objects, so something like BIGAL's recommendation should work. ^C^C_SELECT;_MOVE;0,0,0;0,0,1e99;_MOVE;P;;0,0,0;0,0,-1e99; 1 Quote
leonucadom Posted 8 hours ago Author Posted 8 hours ago 14 hours ago, BIGAL said: It could be as simple as changing "all" to "ss", where ss is a selection set. I am no expert on setting the exclude objects in a selection set. try this not really tested. (setq ss (ssget "_X" '((-4 . "<NOT") (0 . "3DSOLID") (-4 . "NOT>")))) or _move;(setq ss (ssget "_X" '((-4 . "<NOT") (0 . "3DSOLID") (-4 . "NOT>"))));;0,0,0;0,0,1e99;_move;ss;;0,0,0;0,0,-1e99 I already tried it, but something strange happens: it filters the 3D solids, but it puts the other elements at z=1.0000E+99 Quote
Tsuky Posted 1 hour ago Posted 1 hour ago And with this syntax? (sssetfirst nil (ssget "_X" '((0 . "*") (-4 . "<NOT") (0 . "3DSOLID") (-4 . "NOT>")))) Quote
marko_ribar Posted 33 minutes ago Posted 33 minutes ago (ssget "_X" (list (cons 0 "~3DSOLID"))) Quote
