leonucadom Posted Wednesday at 08:59 PM Posted Wednesday at 08:59 PM hello all: I use this routine to lower all selected objects to z0 The problem is that it also affects 3D solids if I have them. Is there a way to modify the code excluding 3D solids from the selection? _move;_all;;0,0,0;0,0,1e99;_move;_p;;0,0,0;0,0,-1e99 I appreciate the comments and hope they can help me. Quote
BIGAL Posted Wednesday at 11:37 PM Posted Wednesday at 11:37 PM (edited) It could be as simple as changing "all" to "ss", where ss is a selection set. I am no expert on setting the exclude objects in a selection set. try this not really tested. (setq ss (ssget "_X" '((-4 . "<NOT") (0 . "3DSOLID") (-4 . "NOT>")))) or _move;(setq ss (ssget "_X" '((-4 . "<NOT") (0 . "3DSOLID") (-4 . "NOT>"))));;0,0,0;0,0,1e99;_move;ss;;0,0,0;0,0,-1e99 Edited Wednesday at 11:50 PM by BIGAL 1 1 Quote
SLW210 Posted 10 hours ago Posted 10 hours ago Here is the button macro for selected objects, so something like BIGAL's recommendation should work. ^C^C_SELECT;_MOVE;0,0,0;0,0,1e99;_MOVE;P;;0,0,0;0,0,-1e99; 1 Quote
leonucadom Posted 9 hours ago Author Posted 9 hours ago 14 hours ago, BIGAL said: It could be as simple as changing "all" to "ss", where ss is a selection set. I am no expert on setting the exclude objects in a selection set. try this not really tested. (setq ss (ssget "_X" '((-4 . "<NOT") (0 . "3DSOLID") (-4 . "NOT>")))) or _move;(setq ss (ssget "_X" '((-4 . "<NOT") (0 . "3DSOLID") (-4 . "NOT>"))));;0,0,0;0,0,1e99;_move;ss;;0,0,0;0,0,-1e99 I already tried it, but something strange happens: it filters the 3D solids, but it puts the other elements at z=1.0000E+99 Quote
Tsuky Posted 2 hours ago Posted 2 hours ago And with this syntax? (sssetfirst nil (ssget "_X" '((0 . "*") (-4 . "<NOT") (0 . "3DSOLID") (-4 . "NOT>")))) Quote
BIGAL Posted 1 hour ago Posted 1 hour ago (edited) Thank you @marko_ribar much simpler. Added look in current Layout or Model. In Civ3D may find surfaces also that are not displayed. (ssget "_X" (list (cons 0 "~3DSOLID")(cons 410 (getvar 'ctab)))) Edited 1 hour ago by BIGAL Quote
Tsuky Posted 1 hour ago Posted 1 hour ago Whether with (ssget "_X" '((0 . "*") (-4 . "<NOT") (0 . "3DSOLID") (-4 . "NOT>"))) or (ssget "_X" (list (cons 0 "~3DSOLID"))), it also dismisses the entities TRACE et SOLID???? Quote
BIGAL Posted 17 minutes ago Posted 17 minutes ago (edited) Using Bricscad dwg has a solid, finds trace. Or do you mean (setq ss (ssget "_X" (list (cons -4 "<NOT") (cons 0 "3DSOLID,TRACE") (cons -4 "NOT>")(cons 410 (getvar 'ctab))))) Edited 15 minutes ago by BIGAL Quote
