Please help with this z0
hello all:
I use this routine to lower all selected objects to z0
The problem is that it also affects 3D solids if I have them.
Is there a way to modify the code excluding 3D solids from the selection?
_move;_all;;0,0,0;0,0,1e99;_move;_p;;0,0,0;0,0,-1e99
I appreciate the comments and hope they can help me.
It could be as simple as changing "all" to "ss", where ss is a selection set.
I am no expert on setting the exclude objects in a selection set. try this not really tested.
(setq ss (ssget "_X" '((-4 . "<NOT") (0 . "3DSOLID") (-4 . "NOT>"))))
or
_move;(setq ss (ssget "_X" '((-4 . "<NOT") (0 . "3DSOLID") (-4 . "NOT>"))));;0,0,0;0,0,1e99;_move;ss;;0,0,0;0,0,-1e99
Edited by BIGAL
  • Agree 1
  • Thanks 1
Here is the button macro for selected objects, so something like BIGAL's recommendation should work.
^C^C_SELECT;_MOVE;0,0,0;0,0,1e99;_MOVE;P;;0,0,0;0,0,-1e99;
  • Thanks 1
or
I already tried it, but something strange happens: it filters the 3D solids, but it puts the other elements at z=1.0000E+99
And with this syntax?
(sssetfirst nil (ssget "_X" '((0 . "*") (-4 . "<NOT") (0 . "3DSOLID") (-4 . "NOT>"))))
  • Thanks 1
Thank you @marko_ribar much simpler. Added look in current Layout or Model. In Civ3D may find surfaces also that are not displayed.
(ssget "_X" (list (cons 0 "~3DSOLID")(cons 410 (getvar 'ctab))))
Edited by BIGAL
Whether with (ssget "_X" '((0 . "*") (-4 . "<NOT") (0 . "3DSOLID") (-4 . "NOT>"))) or (ssget "_X" (list (cons 0 "~3DSOLID"))), it also dismisses the entities TRACE et SOLID????🤔
I was cheated because my selection being numerous, the grips were not actif.et I could not see the highlighting with filled shapes.
Edited by Tsuky
Unfounded remark
Using Bricscad dwg has a solid, finds trace.
Or do you mean
(setq ss (ssget "_X" (list (cons -4  "<NOT") (cons 0 "3DSOLID,TRACE") (cons -4  "NOT>")(cons 410 (getvar 'ctab)))))
Edited by BIGAL
  • Thanks 1
its great, thanks
3 hours ago, leonucadom said:
its great, thanks
This does the same thing (ssget "_X" '((0 . "~3DSOLID")))
It's like Marko's above but CONS is not needed.
