XREF PATH - COPY TO CLIPBOARD
hi,
can anyone please assist creating a lisp to copy the "found at" path of selected xref to clipboard so i can paste the same to open the file in new autocad window. also I suggest to use command XPATH.
the routine would be like:
1. command: XPATH
2. select an XREF
3. message: "found at path copied to clipboard".
4.(command end)
Thanks a lot.
James
Untested I remember Lee Mac saying it was important to release the html obj as it could cause a memory leak or something.
;; Copy Selected Xref Path to Clipboard with prompt.
;; https://www.cadtutor.net/forum/topic/98871-xref-path-copy-to-clipboard
(defun c:XrefToClipBoard (/ SS Blk Path html)
  (vl-load-com)
  (if (setq SS (ssget "_+.:E:S" '((0 . "INSERT"))))
      (setq blk (vla-get-effectivename (vlax-ename->vla-object (ssname SS 0))))
      (setq blk (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) blk))
      (if (= (vla-get-isxref blk) :vlax-true)
          (setq Path (vla-get-Path blk))
          (vlax-invoke (vlax-get (vlax-get (setq html (vlax-create-object "htmlfile")) 'ParentWindow) 'ClipBoardData) 'setData "Text" Path)
          (vlax-release-object html)
          (alert (strcat "\nPath Sent to Clipboard\n Xref Path: " Path))
        (princ "\nSelected Block isn't an Xref.")
    (princ "\nNothing Selected")
-edit
updated code.
Edited by mhupp
  • Like 2
Hi mhupp,
Thank you for the response.
the result says: ; error: ActiveX Server returned the error: unknown name: IsXRef
  • Agree 1
Need to pull the effective block name and check it against the block table. That is where the path is stored. updated code.
Edited by mhupp
Great! it worked, thank you so much!
