ILoveMadoka Posted December 10, 2025 Posted December 10, 2025 (edited) I have a series of PDF sheets created from Revit. When I import a PDF sheet into Autocad, some sheets convert everything to autocad geometry while some other sheets only convert a few lines/text objects. The rest remain and are shown as raster images. What setting(s) controls whether a PDF is seen as vector vs raster by Autocad? Ideally, I'd like to get all the sheets in a PDF format that will import and convert everything in Autocad as usable entities. (I do not think they will convert it to a .dwg format for me). Edited December 11, 2025 by ILoveMadoka Quote
SLW210 Posted December 11, 2025 Posted December 11, 2025 You need to properly set up Revit. PDF is not fully vectorized after exporting it from Revit "Revit will use raster printing because this view uses..." while printing a sheet to PDF format in Revit And check the links at the bottom of those pages. You should be able to Export to a .dwg if that's what you want. Quote
ILoveMadoka Posted December 11, 2025 Author Posted December 11, 2025 I do not have Revit or the original files. The PDFs were provided to me. I would LOVE the .dwg files but we may not be able to get them from a third party vendor. Quote
SLW210 Posted December 11, 2025 Posted December 11, 2025 You need to search for convert Raster to Vector programs. You can use Raster Design on the image files, but still requires some work, it doesn't work on the PDFs though. If they refuse to properly create Vector PDFs or give you a .dwg, your only option is to do them in a separate Raster/Vector program, Raster Design or trace them in AutoCAD. 1 Quote
Steven P Posted January 2 Posted January 2 Didn't read this post earlier, but a word of caution, if the vendor won't send out vector files (PDFs, DWGs), there might be a reason for it - propriety information. But if you can't get them as vectors then as SLW210 says, got to do the work yourself converting raster graphics to proper lines - also be aware in any converted vectors, text drawn as lines and not text and exploded dashed lines, layer names will often be prefixed with PDF_ which I would also convert (I think Lee Mac has a LISP for that). Dimensions might also be off (intentionally?) to be fixed... Yeah, I love PDFs Quote
BIGAL Posted January 2 Posted January 2 If your being provided the pdf's as part of a project, then why are they not provided under some form of copy right agreement. Am I reading between the lines and you have found some pdf's that you want to use without contacting the original authors ? Where I worked we often had out side consultants provide a dwg to us and we had an agreement about how we would use what was provided to us. Quote
ILoveMadoka Posted January 7 Author Posted January 7 Not the case at all. We are "above board", "official requests", "please Sir.." "smoochie smooch" "virgin sacrifice" etc... We are working with architects and in my 35+ years of experience, they are not very agreeable to providing anything to anyone besides print media. In 2026, why would anyone need anything beyond a print in this digital world...? It has always been a [ insert your favorite terms here ] when working with architects in my personal experience. We are using the "powers that be" method to attempt to wrestle original files for our use. no joy so far... Raster -> Vector + Tracing over has been what I have been doing up to this point.. Our client is the same as theirs and they [the client] is expecting digital deliverables. Note the check mark beside "Does not play well with others.." sigh... >>If your being provided the pdf's as part of a project, then why are they not provided under some form of copy right agreement. Ding! Ding! Ding!! Quote
SLW210 Posted January 7 Posted January 7 I have found opening in Photoshop and/or Illustrator and enhancing the raster quality to help. Quote
ILoveMadoka Posted January 12 Author Posted January 12 Illustrator couldn't get everything.... I want to try Inkscape but need to get "special permission" to have it installed.... Quote
SLW210 Posted January 13 Posted January 13 I would keep leaning on the powers that be to get proper .dwgs or at least vector PDFs. Other than that, I most recently converted some raster PDF's to PNG enhanced and cleaned up in GIMP and used Raster Tools in AutoCAD to create AutoCAD objects, worked okay. Quote
