CHAKRADHAR Posted December 16, 2025 Posted December 16, 2025 I am using ZWCAD 2026. A small dot appears near an MTEXT, but I did not create it. When I select the dot, the MTEXT is selected. The dot cannot be deleted, and it is not visible inside the MTEXT editor. Text style used: SIMPLEX (SHX font). This drawing was copied/imported from another file. What is this dot and how can I remove it permanently? Thanks in advance. Quote
CHAKRADHAR Posted December 16, 2025 Author Posted December 16, 2025 CAN U GIVE YOUR EMAIL ADDRESS Quote
fuccaro Posted December 16, 2025 Posted December 16, 2025 Just a word of warning: I would not post my e-mail address in a public post... Quote
SLW210 Posted December 16, 2025 Posted December 16, 2025 No, I'm not giving out my email, nor should anybody else. Just simply provide a new draw with a MText with the problem, you can change the wording as well. It may be something a STRIP FORMATING LISP would fix or maybe go into the MText properties and remove the formatting manually. Anything else and I would need the .dwg. Quote
CHAKRADHAR Posted December 16, 2025 Author Posted December 16, 2025 (edited) Thanks for letting me know. I’ve noted it. Edited December 16, 2025 by CHAKRADHAR Quote
BIGAL Posted December 18, 2025 Posted December 18, 2025 When asked for a sample dwg you can often use WBLOCK to save a little bit of a dwg into a new dwg, like your text. Then it's not a company copyright problem. Quote
