CHAKRADHAR Posted Tuesday at 07:06 AM Posted Tuesday at 07:06 AM I am using ZWCAD 2026. A small dot appears near an MTEXT, but I did not create it. When I select the dot, the MTEXT is selected. The dot cannot be deleted, and it is not visible inside the MTEXT editor. Text style used: SIMPLEX (SHX font). This drawing was copied/imported from another file. What is this dot and how can I remove it permanently? Thanks in advance. Quote
SLW210 Posted Tuesday at 11:22 AM Posted Tuesday at 11:22 AM Can you post a .dwg with this MText? Quote
CHAKRADHAR Posted Tuesday at 11:26 AM Author Posted Tuesday at 11:26 AM CAN U GIVE YOUR EMAIL ADDRESS Quote
fuccaro Posted Tuesday at 12:59 PM Posted Tuesday at 12:59 PM Just a word of warning: I would not post my e-mail address in a public post... Quote
SLW210 Posted Tuesday at 01:04 PM Posted Tuesday at 01:04 PM No, I'm not giving out my email, nor should anybody else. Just simply provide a new draw with a MText with the problem, you can change the wording as well. It may be something a STRIP FORMATING LISP would fix or maybe go into the MText properties and remove the formatting manually. Anything else and I would need the .dwg. Quote
CHAKRADHAR Posted Tuesday at 01:05 PM Author Posted Tuesday at 01:05 PM (edited) Thanks for letting me know. I’ve noted it. Edited Tuesday at 01:06 PM by CHAKRADHAR Quote
BIGAL Posted 10 hours ago Posted 10 hours ago When asked for a sample dwg you can often use WBLOCK to save a little bit of a dwg into a new dwg, like your text. Then it's not a company copyright problem. Quote
