Bob658 Posted Wednesday at 12:22 PM Posted Wednesday at 12:22 PM I have two different models. both have the units set to metres and both have the scale set to 1:1_1. However when the 'Edit Drawing Scales' when you select the 1:1_1 it states at the bottom that '1 paper unit = 1 drawing unit' but in the other model ''1 paper unit = 0.001 drawing unit'. As you can't edit this I'm not sure how it happened. Can anybody shed any light on this.? Quote
CyberAngel Posted Wednesday at 01:13 PM Posted Wednesday at 01:13 PM How is "1:1_1" different from "1:1"? Is it possible there's a duplicate scale? Quote
Bob658 Posted Wednesday at 02:17 PM Author Posted Wednesday at 02:17 PM It's not a duplicate scale. As far as I'm aware 1:1_1 is a standard scale and generally that's the only one I use. Quote
BIGAL Posted 17 hours ago Posted 17 hours ago (edited) Need some more info, are you talking about plotting settings, we worked in metres, and when plotting just set the 1 printed unit = 1 drawing units, our title block was a A1 and if you checked the size of the title block in a layout it was 641x594. For A3 did 1 print = 2 drawing. Or is it annotation scaling ? Edited 17 hours ago by BIGAL Quote
Bob658 Posted 6 hours ago Author Posted 6 hours ago It's causing a plotting issue. The way I work is, model space set to meters and scale is 1:1_1. Paper space is in millimeters. I then set the viewport scale to be whatever I want it to be. I've worked like this since starting using AutoCAD some 25 years ago. Occasionally I get sent a file where this doesn't work and when I look into it, the problem is that for scale 1:1_1 it's set to '1 paper unit = 0.001' drawing unit'. This makes the viewport scale1000 times larger. If I could edit it to be '1 paper unit = 1 drawing unit' it wouldn't be a problem but it won't allow me to edit it. If I'm plotting something at 1:5000 I have to pick the scale 1:5 as a work around. Quote
SLW210 Posted 3 hours ago Posted 3 hours ago I have never seen a standard scale of 1:1_1. Scale Type Scale Description Imperial Architectural 1/4" = 1'-0" (1:48) Commonly used for floor plans 1/8" = 1'-0" (1:96) Used for detail drawings 1/2" = 1'-0" (1:24) For larger details or sections 1" = 1'-0" (1:12) Used for large scale details 3/4" = 1'-0" (1:16) Used for specific areas 1" = 10' -0" (1:120) For site plans or larger layouts Imperial Engineering 1" = 10' (1:120) Used in civil engineering 1" = 20' (1:240) Site plans and large infrastructure 1" = 30' (1:360) Larger site layouts 1" = 40' (1:480) Used for extensive projects Metric 1:1 Full scale 1:10 For large models 1:20 Common for architectural plans 1:50 Used for detail and construction plans 1:100 Site plans and larger structures 1:200 Used for overview layouts 1:500 For urban planning diagrams 1:1000 For regional planning Can you post an example .dwg with a non-editable scale? Quote
CyberAngel Posted 1 hour ago Posted 1 hour ago To test my memory, I opened the default drawing, created a new scale 1:1, and drew a couple of objects and a dimension. I made the dimension annotative and gave it the 1:1 scale. I copied those objects to the clipboard. Then I opened a second new drawing, which had our template settings, including a 1:1 scale. I pasted the objects from the clipboard into the second drawing. You'll never guess what happened. The pasted dimension had a scale of 1:1_1. In other words, that's the type of name AutoCAD gives a duplicate scale when it doesn't want you to rename an arbitrarily large group of settings. Does that shed any light on the issue? Quote
