EIA Posted December 19, 2025 Posted December 19, 2025 This might be too general for a question, but how can you pass a string to a certain cell in an Excel file? Is there any good tutorial out there that you know about Excel and AutoLISP? Quote
BIGAL Posted December 19, 2025 Posted December 19, 2025 Was this posted elsewhere ? Ok first answer you can not use LT2024+ as it does not support the "get application" method. Acad full or Bricscad plus others etc are fine. For LT2025 must use read / write a csv. Happy to provide lots of defuns re Excel to and from but not for LT. Quote
EIA Posted December 19, 2025 Author Posted December 19, 2025 There probably is a post like this since it is quite a generic theme, but I didn't find it. OK, so I can't write to excel on LT, but I can write to a .csv; all I need to do is write values then retrieve them through Excel, a .csv should be enough for that, right? Anyway thanks a lot BIGAL. Quote
SLW210 Posted December 19, 2025 Posted December 19, 2025 Doesn't AutoCAD LT have Tables that can Datalink to Excel? AutoCAD LT 2025 Help | About Linking a Table to External Data | Autodesk Quote You can link to an entire spreadsheet, individual row, column, cell, or cell range in Excel. Quote
BIGAL Posted December 19, 2025 Posted December 19, 2025 (edited) You are right its a bit fudgy but you can read a CSV made by Excel, you would have to count lines as row number, then using say lee-mac parse lisp break the line down into individual values representing cells then use a (nth x excelline) where x is the column number in Excel. Like wise make a csv then open in excel. If LT supports you can use (startapp to open Excel and provide the CSV file path & name so it opens it within your lisp saving a step. oh depending on where you are in the world Excel uses a comma or a semicolon for CSV files. Edited December 19, 2025 by BIGAL Quote
