I draw my drawings in model space, but when I go to paper space, the viewport is in landscape mode and I need portrait.  I was able to change it to portrait but now the wireframe (?) is still in landscape mode and I can't get it to change.  In addition to that, what I see in my viewport some of my text and titleblock info doesn't show up but it does in model space.  I have never had these issues before.  I am using autocad 2022.
You're going to need a different layout for that. Most important thing to learn is creating layouts with templates you can import into other drawings. Once you have them you'll be able to drawings much faster since you shouldn't ever need to do it again. The link to AutoCAD Foundations in AutoCAD Help below is the best place to start.
Organize and Output a Design with Layouts (AutoCAD Foundations) https://help.autodesk.com/view/ACD/2026/ENU/?guid=ACD_FOUNDATIONS_MAIN12
AutoCAD provides the best help of any software I know of but as it's hundreds of commands, settings and features that are added to every year you need to dedicate time every day to go through all the help and tutorials you can.
Most of us that have spent decades using AutoCAD and it's verticals still don't claim to know it entirely, it's a journey that keeps gets more comfortable as you go along.
What you'll probably need to do is set the proper coordinate system in your viewport. To make things simpler, you can create the proper view with UCS, give it a name, and save it. That way you can use it as many times as you need to.
To prepare your plan, go to paper space, open the viewport, and "restore" the view. Once you have your linework at the right scale, angle, and location, lock the viewport.
If your model is not supposed to look like a wireframe, check the properties for the Visual Style while in model space.
If this doesn't help, please give us more information.
