(defun c:rm ()
  (setq	roomName
	 (getstring
	   t
	   "\nEnter room type:"
  (null (initget 32))
  (setq fc (getpoint "\nPick first corner"))
  (null (initget 32))
  (setq nc (getcorner fc "\nPick Next corner"))
  (setq	h (abs (- (car fc) (car nc)))
	v (abs (- (cadr fc) (cadr nc)))
  (setq ar (* h v))
  (setq	txt (strcat roomName
		    "\\P"
		    (rtos h 2 2)
		    " M "
		    " X "
		    (rtos v 2 2)
		    " M "
		    "\\P"
		    (rtos ar 2 2)
		    " SQ.M.]"
(command "rectangle" fc nc)
  (setq p (mapcar (function (lambda (a b) (/ (+ a b) 2.00))) fc nc))
  (entmakex
    (list
      (cons 0 "MTEXT")
      (cons 8 "ROOM")					      ; your layer name
      (cons 62 5)						      ; text color blue
      (cons 7 "Standard")					      ; text style name
      (cons 100 "AcDbEntity")
      (cons 100 "AcDbMText")
      (cons 10 p)
      (cons 1 txt)
      (cons 41 0)						      ; Text width
      (cons 71 5)
      (cons 72 5)
      (cons 73 1)
      (cons 40 0.23)
Convert the rectangle (only) into a block, placing the point at the bottom left corner.
Drawing2.dwg
Edited by maahee
Add this code below '(command " rectangle"... ', load it, and try running the code again
  (if (not (tblsearch "block" roomName))
    (command "_block" roomName (setq pt (list (min (car fc) (car fc)) (min (cadr fc) (cadr fc)))) (setq cj (ssadd (entlast))) "")
    (princ (strcat "\n" roomName " already exist..."))
  (command "_.insert" roomName pt "" "" "")
  • Thanks 1
