Title Block with Updateable Zones?
First of all....I'm barely a noob with Revit. Learning via youtube.
We use Autocad title blocks with zone Letters & Numbers. (A,B,C,D on sides, 1-8 [numbers] on the bottom and top)
We are about to start our first Revit project.
What is the recommendation if we want to use zones on all Revit sheets?
Make it text and have to manually update each sheet?
I didn't know if Labels can be made is such a way as to update per the sheet they are located on?
please be gentle.... It's my first time..
Nope. Revit works on Parameters. Try to read about Types and Instance Parameters as well as Project Information.
These are the things that are to be used in your title blocks. As well as Visibility Parameters for your Key Plan.
