Was looking for something to rename blocks, and have found Lee Mac's code robust since it can handle dynamic blocks, and renames only the particular block selected, so it has a unique name.
https://www.lee-mac.com/copyblock.html
How can code be adjusted for the following.
1. Select block first, then run code (will right click to select command which runs code). At the moment code is called up, then block is selected.
2. When block name is changed, it will be at the end of the string, based on existing name. Tried to press End on keyboard to get to the end of the name but this won't work, the arrow keys do work but it starts from the beginning. See below.
Edited by sketch11
Lee's code is above my pay grade. He has CB and RB broken out already maybe ask him nicely to add a feature.
RBP - rename block with prefix
RBS - rename block with Suffix
-edit
I think I have code that will do this for regular blocks or maybe it was for text. its been awhile.
Edited by mhupp
