Was looking for something to rename blocks, and have found Lee Mac's code robust since it can handle dynamic blocks, and renames only the particular block selected, so it has a unique name.
https://www.lee-mac.com/copyblock.html
How can code be adjusted for the following.
1. Select block first, then run code (will right click to select command which runs code). At the moment code is called up, then block is selected.
2. When block name is changed, it will be at the end of the string, based on existing name. Tried to press End on keyboard to get to the end of the name but this won't work, the arrow keys do work but it starts from the beginning. See below.
Edited by sketch11
Lee's code is above my pay grade. He has CB and RB broken out already maybe ask him nicely to add a feature.
RBP - rename block with prefix
RBS - rename block with Suffix
-edit
I think I have code that will do this for regular blocks or maybe it was for text. its been awhile.
Edited by mhupp
Ok thanks mhupp.
Do you know of a web page which has instructions on how to write LISP code after an object is selected.
only tested this on regular blocks. if you use prefix on anonymous blocks they might not be anonymous anymore. I don't know what would happen so test it first before using it on project files.
@Lee Mac let me know if you want this taken down. probably do it Monday anyway.
Rename.lsp
Maybe (setq ss (ssget "I")) just select objects 1st then run in a lisp. A google revealed..
Thanks mhupp, but I didn't want to add prefix or suffix, actually preferred to leave name unchanged, just wanted to press End on keyboard to get to the end of the string.
Not so sure you can do 'end' with the keyboard with the standard (getstring) functions - either live with it or perhaps a DCL pop up might let you do this. Should be able to amend Lees Code to insert a dialogue if it really is necessary.
Change this line to call another function with the code needed, return value will be the string that (setq new is looking for:
(setq new (strcat (getstring t (strcat "\nPrefix For Block <" def ">: ")) " " old)))
Edited by Steven P
Maybe with this subterfuge?
(defun c:foo ( / src dxf app doc scr old new)
  (while
      (setvar 'errno 0)
      (setq src (car (entsel (strcat "\nSelect block reference: "))))
      (cond
        ((= 7 (getvar 'errno))
            (princ "\nMissed, try again.")
        ((= 'ename (type src))
            (setq dxf (entget src))
          (cond
            ((/= "INSERT" (cdr (assoc 0 dxf)))
                 (princ "\nPlease select a block reference.")
            ((= 4 (logand 4 (cdr (assoc 70 (tblsearch "layer" (cdr (assoc 8 dxf)))))))
                (princ "\nSelected block is on a locked layer.")
  (if (= 'ename (type src))
      (setq app (vlax-get-acad-object)
            doc (vla-get-activedocument app)
            src (vlax-ename->vla-object src)
            old (vlax-get-property src (if (vlax-property-available-p src 'effectivename) 'effectivename 'name))
            new (strcat old (getstring t (strcat "\nSpecify new block name <" old ">: " (princ (strcat "\n" old)))))
      (cond
        ((and
          (= "" new)
          (or (not (snvalid new)) (tblsearch "block" new))
          (princ "\nBlock name invalid or already exists.")
        (T (command "_.rename" "_block" old new))
  (prin1)
