Hi all, long time i faced problem with polylines. One app create bunch of polylines with not 90 deg corners between near parts if i use custom method inside that APP, but nevermind. I am looking for app that can adjust verterxes of polyine in way when polyline become fully orthogonal in current UCS, but keeps the first and last verters untoched (that can break further calculations). Example before/after below:
image.png.8973e69396fc141f34537a9c4a018c72.pngimage.png.07f1cf1595c82eb95d613c391cfc08a4.png
Honestly i am tired of manally adjusted them every time, by moving each verterx far away then back with orho turned ON to make in 90 deg to previous vertex.
Thanks for every help
chat made this,
(defun orthogonalize-points (pts / dx-in dx-out dy-in dy-out i in-is-h new-x new-y out-is-h p0 p1 p2 result)
  ;; If fewer than 3 points, nothing to do
  (if (< (length pts) 3)
    pts
      (setq result pts)
      ;; Iterate interior vertices
      (setq i 1)
      (while (< i (- (length pts) 1))
        (setq p0 (nth (- i 1) result))
        (setq p1 (nth i result))
        (setq p2 (nth (+ i 1) result))
        ;; Incoming vector p0 -> p1
        (setq dx-in (- (car p1) (car p0)))
        (setq dy-in (- (cadr p1) (cadr p0)))
        ;; Outgoing vector p1 -> p2
        (setq dx-out (- (car p2) (car p1)))
        (setq dy-out (- (cadr p2) (cadr p1)))
        ;; Dominant direction tests
        (setq in-is-h  (>= (abs dx-in)  (abs dy-in)))
        (setq out-is-h (>= (abs dx-out) (abs dy-out)))
        ;; Case 1: Proper corner (one horizontal, one vertical)
        (cond
          ((/= in-is-h out-is-h)
           (if in-is-h
               ;; incoming horizontal, outgoing vertical
               (setq new-x (car p2))
               (setq new-y (cadr p0))
               ;; incoming vertical, outgoing horizontal
               (setq new-x (car p0))
               (setq new-y (cadr p2))
          ;; Case 2: both horizontal
          (in-is-h
           (setq new-x (car p1))
          ;; Case 3: both vertical
          (t
           (setq new-y (cadr p1))
        ;; Replace interior point
        (setq result
              (subst (list new-x new-y) p1 result))
        (setq i (1+ i))
      result
(defun c:ORTHO_PLINE ( / edata ent newpts p pl pts x)
  (setq ent (car (entsel "\nSelect a polyline: ")))
  (if (not ent)
      (princ "\nNothing selected.")
      (exit)
  (setq edata (entget ent))
  ;; Ensure LWPOLYLINE
  (if (/= (cdr (assoc 0 edata)) "LWPOLYLINE")
      (princ "\nEntity is not a lightweight polyline.")
      (exit)
  ;; Extract vertices (group code 10)
  (setq pts
        (mapcar 'cdr
                (vl-remove-if-not
                  '(lambda (x) (= (car x) 10))
                  edata)))
  ;; Orthogonalize
  (setq newpts (orthogonalize-points pts))
  ;; Create new polyline
  (setq pl
        (entmakex
          (append
            (list
              '(0 . "LWPOLYLINE")
              '(100 . "AcDbEntity")
              '(100 . "AcDbPolyline")
              (cons 90 (length newpts))
              '(70 . 0)
            (mapcar '(lambda (p) (cons 10 p)) newpts)
  (if pl
    (princ "\nOrthogonal polyline created.")
    (princ "\nFailed to create polyline.")
A slightly blunter method I use is to line everything up to a grid spacing (in my LISP I define the spacing rather than the drawing.... just in case) which usually works OK for most thing. A lot of what I do is line diagrams and the polylines are never too far out.
 - Get a list of points, use Lee Macs round to closest on each point, entmod the line using original and new points. I'd prefer entmod than making a new line just in case something goes wrong in between deleting the original and creating the new, retains all the original polyline info.
  • Agree 1
@Danielm103
How can AI be better than human revision?
Here is AI - I've added "red" color...
(defun c:ortho_pline ( / orthogonalize-points edata ent newpts p pl pts x)
      pts
        (setq result pts)
        (setq i 1)
          (cond
             (if in-is-h
            (in-is-h
            (t
          (setq result
          (setq i (1+ i))
        result
  (if (not ent)
      (exit)
      (exit)
  (setq pts
        (mapcar 'cdr
                (vl-remove-if-not
                  edata)))
  ;; Orthogonalize
  (setq pl
        (entmakex
          (append
            (list
              '(0 . "LWPOLYLINE")
              '(70 . 0)
            (list '(62 . 1))
  (if pl
And here is my version - I used "green" color...
(defun c:lw_orth ( / un f lw lwx pl cl )
  (defun un ( l / a ll )
    (while (setq a (car l))
      (if (vl-some (function (lambda ( x ) (equal x a 1e-10))) l)
        (setq ll (cons a ll) l (vl-remove-if (function (lambda ( x ) (equal x a 1e-10))) (cdr l)))
        (setq ll (cons a ll) l (cdr l))
    (reverse ll)
  (defun f ( l / i p1 p2 r )
    (if (> (length l) 2)
        (setq i -1)
        (while (< (setq i (1+ i)) (1- (length l)))
          (if (not p1)
            (setq p1 (nth i l) p2 (nth (1+ i) l))
            (setq p1 p2 p2 (nth (1+ i) l))
          (if (= i 0)
            (setq r (cons (car l) r))
          (if (< (abs (- (car p2) (car p1))) (abs (- (cadr p2) (cadr p1))))
            (setq r (cons (setq p2 (list (car p1) (cadr p2))) r))
            (setq r (cons (setq p2 (list (car p2) (cadr p1))) r))
          (if (= i (- (length l) 2))
            (setq r (cons (last l) r))
        (setq r (reverse r))
        (un (apply (function append) (mapcar (function (lambda ( p1 p2 / pp ) (if (setq pp (vl-some (function (lambda ( x ) (if (and (equal (distance p1 p2) (+ (distance p1 x) (distance x p2)) 1e-10) (not (equal x p1 1e-10)) (not (equal x p2 1e-10))) x))) l)) (list p1 pp) (list p1)))) r (append (cdr r) (list (car r))))))
  (if
    (and
      (setq lw (car (entsel "\nPick polygonal lwpolyline to make its clone orthogonalized...")))
      (= (cdr (assoc 0 (setq lwx (entget lw)))) "LWPOLYLINE")
      (vl-every (function (lambda ( x ) (= (cdr x) 0.0))) (vl-remove-if (function (lambda ( x ) (/= (car x) 42))) lwx))
      (if (or (= (cdr (assoc 70 lwx)) 1) (= (cdr (assoc 70 lwx)) 129))
        (setq cl t)
      (setq pl (mapcar (function (lambda ( p ) (trans p lw 1))) (mapcar (function cdr) (vl-remove-if (function (lambda ( x ) (/= (car x) 10))) lwx))))
      (if cl
        (setq pl (append pl (list (car pl))))
      (if (> (length pl) 2)
        (entmake
          (append
            (list
              (cons 0 "LWPOLYLINE")
              (cons 100 "AcDbEntity")
              (cons 100 "AcDbPolyline")
              (cons 90 (length (setq pl (f pl))))
              (cons 70 (if cl (1+ (* 128 (getvar (quote plinegen)))) (* 128 (getvar (quote plinegen)))))
              (cons 38 0.0)
            (mapcar (function (lambda ( x ) (cons 10 x))) (mapcar (function (lambda ( p ) (trans p 1 lw))) pl))
            (list
              (cons 62 3)
              (list 210 0.0 0.0 1.0)
        (prompt "\nPicked lwpolyline with insufficient number of vertices...")
    (prompt "\nMissed, or picked entity not polygonal lwpolyline... Better luck next time...")
In attached *.DWG you can see that AI version makes mistake with finalizing segment - it isn't always orthogonal...
Anyway interesting and fun for coding...
Regards, M.R.
orthogonalize_lwpolyline.dwg
Edited by marko_ribar
  • Like 4
Maybe another function that could help you...
It is essential to set the "RESOL" variable to your resolution wishes before starting the routine, note that this modifies the geometry data of all selected objects.
(defun round_number (xr n / )
  (* (fix (atof (rtos (* xr n) 2 0))) (/ 1.0 n))
(defun c:regular_draw ( / js n_count ent dxf_ent dxf_lst)
  (setq js (ssget '((0 . "FACE3D,ARC,ATTDEF,ATTRIB,CIRCLE,ELLIPSE,INSERT,LINE,POLYLINE,LWPOLYLINE,*TEXT,POINT,SHAPE,SOLID,TRACE"))) n_count -1)
  (cond
    (js
      (setvar "cmdecho" 0)
      (command "_.undo" "_group")
      (while (setq ent (ssname js (setq n_count (1+ n_count))))
        (setq dxf_ent (entget ent))
        (cond
          ((eq (cdr (assoc 0 dxf_ent)) "LWPOLYLINE")
            (setq dxf_lst (cdr dxf_ent) dxf_ent (list (car dxf_ent)))
            (while (cdr dxf_lst)
              (if (eq 10 (caar dxf_lst))
                (setq dxf_ent (cons (cons 10 (mapcar '(lambda (x p) (round_number x (/ 1 p))) (cdar dxf_lst) (getvar "SNAPUNIT"))) dxf_ent))
                (setq dxf_ent (cons (car dxf_lst) dxf_ent))
              (setq dxf_lst (cdr dxf_lst))
            (setq dxf_ent (reverse dxf_ent))
          ((eq (cdr (assoc 0 dxf_ent)) "POLYLINE")
            (while (eq (cdr (assoc 0 (setq dxf_ent (entget (entnext (cdar dxf_ent)))))) "VERTEX")
              (setq dxf_ent (subst (cons 10 (mapcar '(lambda (x p) (round_number x (/ 1 p))) (cdr (assoc 10 dxf_ent)) (append (getvar "SNAPUNIT") (list (car (getvar "SNAPUNIT")))))) (assoc 10 dxf_ent) dxf_ent))
              (entmod dxf_ent)
          (T
            (foreach n dxf_ent
              (if (member (car n) '(10 11 12 13 40))
                (if (listp (cdr n))
                  (setq dxf_ent (subst (cons (car n) (mapcar '(lambda (x p) (round_number x (/ 1 p))) (cdr n) (append (getvar "SNAPUNIT") (list (car (getvar "SNAPUNIT")))))) (assoc (car n) dxf_ent) dxf_ent))
                  (setq dxf_ent (subst (cons (car n) (round_number (cdr n) (/ 1 (car (getvar "SNAPUNIT"))))) (assoc (car n) dxf_ent) dxf_ent))
        (entmod dxf_ent)
        (entupd ent)
      (command "_.undo" "_end")
      (setvar "cmdecho" 1)
      (princ (strcat "\n" (itoa n_count) " transformed object(s)."))
    (T (princ "\nNo find valid object."))
  (prin1)
10 hours ago, marko_ribar said:
@Danielm103
      pts
        (setq result pts)
        (setq i 1)
          (cond
             (if in-is-h
            (in-is-h
            (t
          (setq result
          (setq i (1+ i))
        result
  (if (not ent)
      (exit)
      (exit)
  (setq pts
        (mapcar 'cdr
                (vl-remove-if-not
                  edata)))
  ;; Orthogonalize
  (setq pl
        (entmakex
          (append
            (list
              '(0 . "LWPOLYLINE")
              '(70 . 0)
            (list '(62 . 1))
  (if pl
(defun c:lw_orth ( / un f lw lwx pl )
    (reverse ll)
        (setq i -1)
          (if (not p1)
          (if (= i 0)
  (if
    (and
      (setq lw (car (entsel "\nPick open polygonal lwpolyline to make its clone orthogonalized...")))
      (or (= (cdr (assoc 70 lwx)) 0) (= (cdr (assoc 70 lwx)) 128))
      (setq pl (mapcar (function cdr) (vl-remove-if (function (lambda ( x ) (/= (car x) 10))) lwx)))
        (entmake
          (append
            (list
              (cons 70 (* 128 (getvar (quote plinegen))))
              (cons 38 0.0)
            (mapcar (function (lambda ( x ) (cons 10 x))) pl)
            (list
              (cons 62 3)
    (prompt "\nMissed, or picked entity not open polygonal lwpolyline... Better luck next time...")
Regards, M.R.
Hi, does it possible to take into account UCS also?
I tried to use it in real routine job. Result is above.
  (cond
    (js
        (cond
              (entmod dxf_ent)
          (T
            (foreach n dxf_ent
                (if (listp (cdr n))
        (entmod dxf_ent)
        (entupd ent)
  (prin1)
Thanks, could you help me to use that code. I put that in lisp editor, saved, used appload to load lisp. But i can find these comands to use, either "round_number" or "regular_draw"
Where am i wrong?
Where am i wrong?
The command is "regular_draw", but before to execute it set the variable "RESOL" (value near to your delta X and Y)
I guess you wanted to be orthogonal in relation to current UCS... It is working as desired according to picture you posted... If you always want to make it work in relation to WCS, then you add this line as first : (command "_,ucs" "_w") , and last one should be : (command "_.ucs" "_p")...
As for @Tsuky code, you just push that first (defun round_number ... ) into body of main command function (c:regular_draw) and localize it after main defun (defun c:regular_draw ( / round_number js n_count ent dxf_ent dxf_lst), then you save *.lsp as : "regular_draw.lsp" file, then use APPLOAD command and point to saved "regular_draw.lsp"; CAD should return message : successfuly loaded lisp... Then all you should do is type at Command: regular_draw... You'll be asked to select objects and upon selecting and pressing ENTER, all vertices should jump onto coordinates that are whole numbers (no decimal expansions) [if your SNAPUNIT sys variable is default - 1.0,1.0]... Still with @Tsuky routine, original polylines (or/and other entity types that were selected) will only slightly change vertices positions and therefore it may turn out that orthogonalism won't be processed... So IMHO, you should use both (c:regular_draw) and (c:lw_orth) to make your drawing without problematic portions where inaccuracies of drawn objects may occur...
Hi, first of all thanks a lot, i am only beginner in my LISP journey, and for me its hard to find good info in my native lang, so any usefull help is excelent.
About UCS it worked fine, lw_orth now creates line in any UCS.  (command "_,ucs" "_w") and (command "_.ucs" "_p") worked out!
About regular_draw i tried to implement stuff you descriibed in post, but after that console says next:
I setted SNAPUNIT to 1.0,1.0 as you said. Could you help me where am i wrong in adjusting regular_draw comand, it seems what i was looking for
If you want to load lisp as it is, then you shouldn't localize that first (defun) along with other variables... Only if you push it (that first defun) in main body of command function (defun c:) you should localize it, wich is what I suggested... As you observed CAD won't recognize localized defun if it's out of main command function and bahave like global variable, though as if you had globals they should never be localized as they also won't be recognized...
  • 2 weeks later...
Not sure if OP is still online, but IMHO, I think this update is better...
(defun c:lw_orth ( / un f p lw lwx pl cl )
    (reverse ll)
  (defun f ( l / i p1 p2 px r )
        (setq i -1)
          (if (not p1)
          (if (= i 0)
          (setq r (cons (if (setq px (p p1 p2 p2)) (setq p2 px) p2) r))
  (defun p ( p1 p2 p3 / p21 p22 )
    (setq p21 (inters p1 (polar p1 (* 0.5 pi) 1.0) p3 (polar p3 0.0 1.0) nil))
    (setq p22 (inters p1 (polar p1 0.0 1.0) p3 (polar p3 (* 0.5 pi) 1.0) nil))
    (if (< (distance p2 p21) (distance p2 p22))
      p21
      p22
  (if
    (and
        (setq cl t)
      (if cl
        (entmake
          (append
            (list
              (assoc 38 lwx)
            (list
              (cons 62 3)
              (assoc 210 lwx)
(defun c:lw_orth-grread ( / un f p lw lwx pl ppl cl lwn lwnx gr pp pre suf )
    (reverse ll)
        (setq i -1)
          (if (not p1)
          (if (= i 0)
      p21
      p22
  (if
    (and
        (setq cl t)
      (if cl
        (setq lwn
          (entmakex
            (append
              (list
                (cons 90 (length (setq ppl (f pl))))
                (assoc 38 lwx)
              (mapcar (function (lambda ( x ) (cons 10 x))) (mapcar (function (lambda ( p ) (trans p 1 lw))) ppl))
              (list
                (cons 62 3)
                (assoc 210 lwx)
      (vl-cmdf "_.ucs" "_m" (mapcar (function +) (list 0.0 0.0) (getvar (quote viewctr))))
      (if (and lwn (setq lwnx (entget lwn)) (setq pre (reverse (member (assoc 39 lwnx) (reverse lwnx)))) (setq suf (list (assoc 210 lwnx))))
        (while (= (car (setq gr (grread t))) 5)
          (setq pp (cadr gr))
          (vl-cmdf "_.ucs" "_3p" "_non" (list 0.0 0.0) "_non" pp "")
          (if cl
          (setq pre (subst (cons 90 (length (setq ppl (f pl)))) (assoc 90 pre) pre))
          (entupd (cdr (assoc -1 (entmod (append pre (mapcar (function (lambda ( x ) (cons 10 x))) (mapcar (function (lambda ( p ) (trans p 1 lw))) ppl)) suf)))))
BTW. As addition to previous version, now there is (grread) implementation... (grsnap) is here unnecessary...
HTH.
Regards, M.R.
  • Like 2
    (reverse ll)
        (setq i -1)
          (if (not p1)
          (if (= i 0)
      p21
      p22
  (if
    (and
        (setq cl t)
      (if cl
        (entmake
          (append
            (list
              (assoc 38 lwx)
            (list
              (cons 62 3)
              (assoc 210 lwx)
    (reverse ll)
        (setq i -1)
          (if (not p1)
          (if (= i 0)
      p21
      p22
  (if
    (and
        (setq cl t)
      (if cl
        (setq lwn
          (entmakex
            (append
              (list
                (assoc 38 lwx)
              (list
                (cons 62 3)
                (assoc 210 lwx)
          (setq pp (cadr gr))
          (if cl
HTH.
Regards, M.R.
Hi, many thanks for keep responding. Due to electrical difficulties in UA, i cant check daily, i will try that and ur previous respond and comeback.
God bless
I've added (c:lw_orth-2) and (c:lw_orth-grread-2), but IMHO, version 1 is better...
Here is link...
Regards, M.R.
I've finished with "lw_orth.lsp"... Take it, or leave it... It's up to you OP...
I've found some lacks in latest updates - in 3d with ucs aligned in 3d with lwpolylines (grread-mult) versions produced unwanted behaviour...
Hopefully now fixed... Also, added (vl-cmdf "_.undo" "_m") as first line at each command function, so upon finished execution, you can just use UNDO (Back) to return before running command...
There was 5 downloads till I reattached fixed version...
Sorry for inconvenience - it happens from time to time...
Regards, M.R.
orthogonalize_lwpolyline-ucs3D.dwg
lw_orth.lsp
  • Like 2
I found some lacks, so I had to change my latest attachments...
M.R.
Really nice Marko! Handy cleaning tool, really does help. Thanks again
  • 1 month later...
M.R.
Hi, you did a fantastic job. The few options is realy good, and handy to use. I have only 1 question left - can that tool not create a clone of polyline, but edit current? To transform polyline with all parameters and e.t.c.
If you will be doing that, its nessesary obly for lw_orth_2 (2nd version) it works better for cases i have faced. Does it even possible to transform line like it doing it not with clone?
Thanks you very much already!!!
