Hi Team,
I wish to create a Lisp code that has the following conditions,
1). Create a mtext above the new draw polyline. The mtext shall be created in every segment of the polyline. The mtext to follows the direction of the polyline.
2). The mtext to be content "BD/1:200/3.0m" above the polyline. The 3.0m is the variable that refers to the length of the particular polyline segment length.
3). The mtext to be layer SNA-TXT and text height 1000.
Kindly advise the lisp code above. Thanks.
Hi @karfung,
Try this and see if it fits to your needs:
; Functions     :  PLMTXT
; Description   :  Add predefined text with length segment between two vertices on polyline
; Author        :  Saxlle
; Date          :  January 18, 2026
(prompt "\nTo run a LISP type: PLMTXT")
(defun c:PLMTXT ( / old_osmode cur_layer old_nomutt height def_text ss len i dxf_70 plist dataList n k pt1 pt2 midPt ang dist npt pt lenSegment)
  (setq old_osmode (getvar 'osmode)
	cur_layer (getvar 'clayer)
	old_nomutt (getvar 'nomutt)
	height (getreal "\nEnter the text height <2.50>: ") ;; text height
	def_text "BD/1:200/" ;; default text
  (if (= height nil)
    (setq height 2.50) ;; defaul text height, it can be changed
  (setvar 'osmode 0)
  (if (not (tblsearch "LAYER" "SNA-TXT")) ;; check does layer 'SNA-TXT' exist or not
    (command-s "-layer" "m" "SNA-TXT" "") ;; make the SNA-TXT layer and set to be the current
    (command-s "-layer" "s" "SNA-TXT" "") ;; set the SNA-TXT layer to be the current
  (setvar 'nomutt 1)
  (princ "\nSelect POLYLINES:")
  (setq ss (ssget (list (cons 0 "LWPOLYLINE")))
	len (sslength ss)
	plist (list)
	i 0
  (setvar 'nomutt old_nomutt)
  (while (< i len)
    (setq dxf_70 (cdr (assoc 70 (entget (ssname ss i)))))
    (cond
      ;; the first cond
      ((= dxf_70 0) ;; LWPOLYLINE is OPEN
       (setq plist (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (ssname ss i))))
	     dataList (list)
	     n 0
	     k 1
       (repeat (setq l (length plist))
	 (if (< k l)
	     (setq pt1 (nth n plist)
		   pt2 (nth k plist)
		   midPt (mapcar '* (mapcar '+ pt1 pt2) (list 0.5 0.5))
		   ang (ang_check_text (angle pt1 pt2))
		   dist (distance pt1 pt2)
		   npt (polar midPt (+ (angle pt1 pt2) (/ pi 2)) height)
		   dataList (append (list (list npt ang dist)) dataList)
		   n (1+ n)
		   k (1+ k)
       (setq dataList (reverse dataList)
	     n 0
       (repeat (length dataList)
	 (setq pt (car (nth n dataList))
	       ang (cadr (nth n dataList))
	       lenSegment (caddr (nth n dataList))
	       n (1+ n)
	 (entmake (list (cons 0 "MTEXT") (cons 100 "AcDbEntity") (cons 100 "AcDbMText") (cons 10 pt) (cons 11 pt) (cons 40 height) (cons 50 ang)
			(cons 71 5) (cons 1 (strcat def_text (rtos lenSegment 2 2) " m"))))
      ) ;; end first cond
      ;; the second cond
      ((= dxf_70 1) ;; LWPOLYLINE is CLOSED
	     dataList (list)
	     n 0
	     k 1
	 (if (< k l)
		   pt2 (nth k plist)
		   n (1+ n)
		   k (1+ k)
	     (setq n 0
		   k (1- k)
	           pt1 (nth k plist)
		   pt2 (nth n plist)
	     n 0
	       n (1+ n)
      ) ;; end second cond
    ) ;; end cond
    (setq i (1+ i))
  (setvar 'osmode old_osmode) ;; restore osmode
  (setvar 'clayer cur_layer) ;; restore old layer
  (prompt "\nThe text was inserted!")
  ;; Sub-function to get a proper text angle
  (defun ang_check_text (ang)
    (cond
      ((<= ang 1.57)
       (setq ang ang)
      ((and (>= ang 1.57) (<= ang 3.14))
       (setq ang (+ ang pi))
      ((and (>= ang 3.14) (<= ang 4.71))
       (setq ang (- ang pi))
      ((>= ang 4.71)
       (setq ang ang)
Also, see the short video example of how it works.
Best regards.
Edited by Saxlle
  • Thanks 1
40 minutes ago, Saxlle said:
Hi @karfung,
; Author        :  Saxlle
  (if (= height nil)
  (setvar 'osmode 0)
  (setvar 'nomutt 1)
	len (sslength ss)
	plist (list)
	i 0
  (while (< i len)
    (cond
      ;; the first cond
	     dataList (list)
	     n 0
	     k 1
	 (if (< k l)
		   pt2 (nth k plist)
		   n (1+ n)
		   k (1+ k)
	     n 0
	       n (1+ n)
      ) ;; end first cond
      ;; the second cond
	     dataList (list)
	     n 0
	     k 1
	 (if (< k l)
		   pt2 (nth k plist)
		   n (1+ n)
		   k (1+ k)
	     (setq n 0
		   k (1- k)
	           pt1 (nth k plist)
		   pt2 (nth n plist)
	     n 0
	       n (1+ n)
    ) ;; end cond
    (setq i (1+ i))
    (cond
      ((<= ang 1.57)
       (setq ang ang)
      ((>= ang 4.71)
       (setq ang ang)
Best regards.
@Saxlle Yeah, this is what I wanted. Really awesome and your prompt response. Thank you.
I am from Malaysia. May I know where you from? Thanks.
I am from Malaysia.
Land of Durian, yummy
1 hour ago, Saxlle said:
Hi @karfung,
; Author        :  Saxlle
  (if (= height nil)
  (setvar 'osmode 0)
  (setvar 'nomutt 1)
	len (sslength ss)
	plist (list)
	i 0
  (while (< i len)
    (cond
      ;; the first cond
	     dataList (list)
	     n 0
	     k 1
	 (if (< k l)
		   pt2 (nth k plist)
		   n (1+ n)
		   k (1+ k)
	     n 0
	       n (1+ n)
      ) ;; end first cond
      ;; the second cond
	     dataList (list)
	     n 0
	     k 1
	 (if (< k l)
		   pt2 (nth k plist)
		   n (1+ n)
		   k (1+ k)
	     (setq n 0
		   k (1- k)
	           pt1 (nth k plist)
		   pt2 (nth n plist)
	     n 0
	       n (1+ n)
    ) ;; end cond
    (setq i (1+ i))
    (cond
      ((<= ang 1.57)
       (setq ang ang)
      ((>= ang 4.71)
       (setq ang ang)
Best regards.
@Saxlle Could you do me a favour to amend the lisp code as following,
1). My default layout will be in unit mm. Could the length value of the polyline be divided by 1000?
2). The length value of the polyline is to be an integer, and any decimal is to be increased to 1.
Kindly assist to amend the lisp code. Thanks.
Edited by karfung
9 minutes ago, Danielm103 said:
I am from Malaysia.
Please contact me when you reach here. I buy you durian.
You're welcome @karfung 🙂. I'm from Serbia.
I have made changes to the code, please try it now (I hope I understand your requirements correctly). If it's not, try to change in sub-function "fix_value" the value from "500" to any other to get desired result. The fix function round up the real number into the nearest smallest integer number (for e.g. if you have a 3.70 m, and when you add 0.50 m, you will get 4.20 m, but using fix function which is an AutoLISP Core Function, you will get 4.0 m, also if you have 4.70 m, you will also get 4.0 m). Just an explanation to understand the logic.
; Sub-functions :  ang_check_text, fix_value
; Description   :  Add predifined text with the length segment between two vertices on polyline
; Author        :  Saxlle
  (if (= height nil)
  (setvar 'osmode 0)
    (command-s "-layer" "m" "SNA-TXT" "") ;; make the SNA-TXT layer and set to be current
  (setvar 'nomutt 1)
	len (sslength ss)
	plist (list)
	i 0
  (while (< i len)
    (cond
      ;; the first cond
	     dataList (list)
	     n 0
	     k 1
	 (if (< k l)
		   pt2 (nth k plist)
		   dist (/ (fix_value (distance pt1 pt2)) 1000) ;; 1000 mm equal to 1.0 m
		   n (1+ n)
		   k (1+ k)
	     n 0
	       n (1+ n)
      ) ;; end first cond
      ;; the second cond
	     dataList (list)
	     n 0
	     k 1
	 (if (< k l)
		   pt2 (nth k plist)
		   n (1+ n)
		   k (1+ k)
	     (setq n 0
		   k (1- k)
	           pt1 (nth k plist)
		   pt2 (nth n plist)
	     n 0
	       n (1+ n)
    ) ;; end cond
    (setq i (1+ i))
    (cond
      ((<= ang 1.57)
       (setq ang ang)
      ((>= ang 4.71)
       (setq ang ang)
  ;; Sub-function to round up number to the whole integer
  (defun fix_value (val)
    (if (not (minusp val))
      (setq val (fix (+ val 500))) ;; 500 mm equal to 0.50 m
      (setq val (fix (- val 500))) ;; 500 mm equal to 0.50 m
Best regards.
I'v never taste the Durian 🙄.
