Bandido Posted 7 hours ago Posted 7 hours ago Good morning. How can I reduce the file size of this logo? I can't attach it because it's 11MB. How can I post it here? The letters are made with lines and arcs and filled with solid hatching. Thank you very much Quote
SLW210 Posted 6 hours ago Posted 6 hours ago Did you try a -Purge? Make the lines and arcs polylines (Pedit M). Do the solid hatches have a border and also outlined with lines and arcs? If so you only need one or the other or even no border/outline at all since it's solid. You might use a file sharing service (like Dropbox, etc.) to share the file, though for just a check on methods to reduce the file size, you could just post a smaller portion of the logo. Quote
Bandido Posted 5 hours ago Author Posted 5 hours ago Yes. I tried purge, -purge, audit, overkill, and nothing. I am attaching a link with two versions, one made with lines, arcs, and solids, and another with fonts. Thank you. https://we.tl/t-ydngathEMu Quote
SLW210 Posted 58 minutes ago Posted 58 minutes ago I WBlocked them. new Lines and arcs.dwg new font.dwg Quote
Bandido Posted 34 minutes ago Author Posted 34 minutes ago 24 minutes ago, SLW210 said: I WBlocked them. new Lines and arcs.dwg 55.09 kB · 1 download new font.dwg 42.42 kB · 1 download Many thanks. Quote
