Good morning.
How can I reduce the file size of this logo?
I can't attach it because it's 11MB.
How can I post it here?
The letters are made with lines and arcs and filled with solid hatching.
Thank you very much
Did you try a -Purge?
Make the lines and arcs polylines (Pedit M).
Do the solid hatches have a border and also outlined with lines and arcs? If so you only need one or the other or even no border/outline at all since it's solid.
You might use a  file sharing service (like Dropbox, etc.) to share the file, though for just a check on methods to reduce the file size, you could just post a smaller portion of the logo.
Yes.
I tried purge, -purge, audit, overkill, and nothing.
I am attaching a link with two versions, one made with lines, arcs, and solids, and another with fonts.
Thank you.
https://we.tl/t-ydngathEMu
