Bandido Posted January 19 Posted January 19 Good morning. How can I reduce the file size of this logo? I can't attach it because it's 11MB. How can I post it here? The letters are made with lines and arcs and filled with solid hatching. Thank you very much Quote
SLW210 Posted January 19 Posted January 19 Did you try a -Purge? Make the lines and arcs polylines (Pedit M). Do the solid hatches have a border and also outlined with lines and arcs? If so you only need one or the other or even no border/outline at all since it's solid. You might use a file sharing service (like Dropbox, etc.) to share the file, though for just a check on methods to reduce the file size, you could just post a smaller portion of the logo. Quote
Bandido Posted January 19 Author Posted January 19 Yes. I tried purge, -purge, audit, overkill, and nothing. I am attaching a link with two versions, one made with lines, arcs, and solids, and another with fonts. Thank you. https://we.tl/t-ydngathEMu Quote
SLW210 Posted January 19 Posted January 19 I WBlocked them. new Lines and arcs.dwg new font.dwg 1 Quote
Bandido Posted January 19 Author Posted January 19 24 minutes ago, SLW210 said: I WBlocked them. new Lines and arcs.dwg 55.09 kB · 1 download new font.dwg 42.42 kB · 1 download Many thanks. Quote
SLW210 Posted January 20 Posted January 20 Best way to clean a difficult file is WBlock, not sure what had those bloated like that. 1 Quote
Bandido Posted 6 hours ago Author Posted 6 hours ago (edited) Good morning. I used the clean logo placed here by SLW210, but I still have a problem with the weight of the drawings. I've already tried wblock, purge, -purge, and overkill, but nothing works! What could be causing the weight in the drawings? Here is a link to five drawings that have the same problem. Thank you very much for your help. https://we.tl/t-3IquP6IBQ5 Thanks again. Edited 6 hours ago by Bandido Quote
Dahzee Posted 3 hours ago Posted 3 hours ago Trash5.dwgTrash4.dwgTrash3.dwgTrash2.dwgTrash1.dwg I opened your files in Bricscad and did WBLOCK on them, and they all reduced down in size dramatically. I haven't looked to see if anything is missing, so have a look and see if they are OK. The last file I Wblocked complained that there were over 1,500 layer filters. I don't use them myself, but it seems excessive to me (see screenshot file). 1 Quote
Bandido Posted 2 hours ago Author Posted 2 hours ago 19 minutes ago, Dahzee said: Trash5.dwg 373.24 kB · 0 downloads Trash4.dwg 1.19 MB · 0 downloads Trash3.dwg 851.81 kB · 0 downloads Trash2.dwg 260.74 kB · 0 downloads Trash1.dwg 113.28 kB · 0 downloads I opened your files in Bricscad and did WBLOCK on them, and they all reduced down in size dramatically. I haven't looked to see if anything is missing, so have a look and see if they are OK. The last file I Wblocked complained that there were over 1,500 layer filters. I don't use them myself, but it seems excessive to me (see screenshot file). Good morning. Everything looks fine to me. Is wblock in Briscad the same as Autocad? Thank you very much. Quote
Dahzee Posted 2 hours ago Posted 2 hours ago Hi Bandido, I have no idea if it is different as I don't have Autocad. But I'm glad it seemed to have worked for you. 1 Quote
Bandido Posted 2 hours ago Author Posted 2 hours ago 5 minutes ago, Dahzee said: Hi Bandido, I have no idea if it is different as I don't have Autocad. But I'm glad it seemed to have worked for you. I tried something. Just import a word from the old design into these new ones and the weight immediately rises to the value of the originals! Thanks again. Quote
SLW210 Posted 1 hour ago Posted 1 hour ago Are any of your drawings coming from or being worked on in AutoCAD Verticals or other CAD programs? It seems as though there are a lot of excessive tag-alongs in your drawings even when visibly empty. You might also try a DXFOUT and DXFIN to a new drawing. Quote
