Good morning.
How can I reduce the file size of this logo?
I can't attach it because it's 11MB.
How can I post it here?
The letters are made with lines and arcs and filled with solid hatching.
Thank you very much
Did you try a -Purge?
Make the lines and arcs polylines (Pedit M).
Do the solid hatches have a border and also outlined with lines and arcs? If so you only need one or the other or even no border/outline at all since it's solid.
You might use a  file sharing service (like Dropbox, etc.) to share the file, though for just a check on methods to reduce the file size, you could just post a smaller portion of the logo.
Yes.
I tried purge, -purge, audit, overkill, and nothing.
I am attaching a link with two versions, one made with lines, arcs, and solids, and another with fonts.
Thank you.
https://we.tl/t-ydngathEMu
Best way to clean a difficult file is WBlock, not sure what had those bloated like that.
Good morning.
I used the clean logo placed here by SLW210, but I still have a problem with the weight of the drawings. I've already tried wblock, purge, -purge, and overkill, but nothing works!
What could be causing the weight in the drawings?
Here is a link to five drawings that have the same problem.
Thank you very much for your help.
https://we.tl/t-3IquP6IBQ5
Thanks again.
Edited by Bandido
Trash5.dwgTrash4.dwgTrash3.dwgTrash2.dwgTrash1.dwg
I opened your files in Bricscad and did WBLOCK on them, and they all reduced down in size dramatically.
I haven't looked to see if anything is missing, so have a look and see if they are OK.
The last file I Wblocked complained that there were over 1,500 layer filters. I don't use them myself, but it seems excessive to me (see screenshot file).
19 minutes ago, Dahzee said:
Trash5.dwg 373.24 kB · 0 downloads Trash4.dwg 1.19 MB · 0 downloads Trash3.dwg 851.81 kB · 0 downloads Trash2.dwg 260.74 kB · 0 downloads Trash1.dwg 113.28 kB · 0 downloads
Good morning.
Everything looks fine to me.
Is wblock in Briscad the same as Autocad?
Thank you very much.
Hi Bandido, I have no idea if it is different as I don't have Autocad. But I'm glad it seemed to have worked for you.
I tried something.
Just import a word from the old design into these new ones and the weight immediately rises to the value of the originals!
Thanks again.
Are any of your drawings coming from or being worked on in AutoCAD Verticals or other CAD programs?
It seems as though there are a lot of excessive tag-alongs in your drawings even when visibly empty.
You might also try a DXFOUT and DXFIN to a new drawing.
Hi SLW210.
No. I only use AutoCAD 2014. What is Verticals?
It seems that there are too many tag-alongs in your drawings, even when they are visibly empty.
Export to DXF?
Thank you.
Verticals are Civil 3D, AutoCAD Map 3D, AutoCAD Mechanical, AutoCAD Architectural, etc.
I'm busy at work start to finish these days, if I get time I'll see if I can discover the issue.
No, id don't use any of those.
Many thanks.
Are you the only that works on these drawings?
