CREATE PERPENDICULAR DIMENSION BETWEEN TWO PARALLEL POLYLINES
Hello CadTutor fam,
I am a complete newb at creating Lisps. I am trying to create a lisp that automatically places a dimension between two parallel lines (this is a repetitive task in my field). I've attached the lisp I've got so far, but it only places a line perpendicular to the selected lines. Can someone please help out/point me in the right direction?
tpdim.lsp
21 hours ago, SCHNIPPLES said:
Hello CadTutor fam,
@SCHNIPPLES please upload your-sample.dwg
This has been asked before for that task of dimensioning services in roads. I know did something pick base line then pick other lines and all done. Will try to find may have been a few years ago.
6 hours ago, SCHNIPPLES said:
@SCHNIPPLES please give it a try
;; Design and modify  by Gabo CALOS DE VIT from CORDOBA ARGENTINA
;;;    Copyleft 1995-2026 by Gabriel Calos De Vit ; DEVITG@GMAIL.COM
;Hecho y modificado por  Gabo CALOS DE VIT de CORDOBA ARGENTINA
;;;    Copyleft 1995-2026 por Gabriel Calos De Vit
;; DEVITG@GMAIL.COM
;;; inicio-defun-20-ene-2026
;;  as per
;;https://www.cadtutor.net/forum/topic/98950-create-perpendicular-dimension-between-two-parallel-polylines/
(defun c:T5
	    (/		 ACAD-OBJ    acExtendNone	     ADOC	 AT&T-STYLE  BASE-OBJ
	     BASEENT	 CE	     CP1	 DERIV	     DIM-STYLES	 DIM-TXT-PT  DIMOBJ
	     INTS-VAR@BASE	     INTS-VAR@TGT	     INTS@BASE	 INTS@TGT    MODEL
	     NRM	 OS	     P		 P1	     P2		 PARAM	     S
	     SEARCHRAD	 SMPL-DIM    SMPL-DIM-LAY	     SMPL-DIM-STYLE	     SMPL-OBJ
	     TAN	 TGT-OBJ     TGTENT	 TMP-OBJ     TMPE	 X
	    ) ;_ end of /
  (VL-LOAD-COM)
  (SETQ ACAD-OBJ (VLAX-GET-ACAD-OBJECT)) ;_ el programa ACAD
  (SETQ ADOC (VLA-GET-ACTIVEDOCUMENT ACAD-OBJ)) ;_ el DWG que esta abierto-
  (SETQ MODEL (VLA-GET-MODELSPACE ADOC))
  (setq dim-styles (VLA-GET-DIMSTYLES adoc))
  (setq searchRad 2000.0)		; increase if your gaps are big (drawing units)
  (defun v+ (a b) (mapcar '+ a b))
  (defun v- (a b) (mapcar '- a b))
  (defun v* (v s) (mapcar '(lambda (x) (* x s)) v))
  (defun dot (a b)
    (+ (* (car a) (car b))
       (* (cadr a) (cadr b))
       (* (caddr a) (caddr b))
    ) ;_ end of +
  ) ;_ end of defun
  (defun len (v) (sqrt (dot v v)))
  (defun unit (v / L)
    (setq L (len v))
    (if	(> L 1e-12)
      (v* v (/ 1.0 L))
      v
    ) ;_ end of if
  ) ;_ end of defun
  (defun dist (a b) (len (v- a b)))
  (setq os (getvar "OSMODE"))
  (setq ce (getvar "CMDECHO"))
  (setvar "OSMODE" 0)
  (setvar "CMDECHO" 0)
  (alert "\n you have to select a dim you had done ")
  (princ "\n Select a sample dim")
  (setq smpl-dim (ssname (ssget "_:S+." '((0 . "dimension"))) 0))
  (setq baseEnt (car (entsel "\nSelect BASE object (ROW): ")))
  (redraw baseEnt 3)
  (setq base-obj (vlax-ename->vla-object baseEnt))
  (setq tgtEnt (car (entsel "\nSelect TARGET object (BOC/Fiber/etc.): ")))
  (redraw tgtEnt 3)
  (setq tgt-obj (vlax-ename->vla-object tgtEnt))
  (setq	p (getpoint
	    "\nPick dimension location (also picks the side): "
	  ) ;_ end of getpoint
  ) ;_ end of setq
  (if (and baseEnt tgtEnt p)
      ;; Closest point on base
      (setq cp1 (vlax-curve-getClosestPointTo baseEnt p))
      ;; Tangent derivative at cp1
      (setq param (vlax-curve-getParamAtPoint baseEnt cp1))
      (setq deriv (vlax-curve-getFirstDeriv baseEnt param))
      (setq tan (unit deriv))
      ;; Normal (perpendicular) in XY
      (setq nrm (unit (list (- (cadr tan)) (car tan) 0.0)))
      ;; Build long perpendicular segment through cp1
      (setq p1 (v- cp1 (v* nrm searchRad)))
					;(setq point@p1 (VLA-ADDPOINT model (VLAX-3D-POINT p1)))
      (setq p2 (v+ cp1 (v* nrm searchRad)))
					;(setq point@p2 (VLA-ADDPOINT model (VLAX-3D-POINT p2)))
      ;; Create temp LINE entity (so we can intersect reliably)
      (setq tmpE
	     (entmakex
	       (list (cons 0 "LINE")
		     (cons 10 p1)
		     (cons 11 p2)
	       ) ;_ end of list
	     ) ;_ end of entmakex
      ) ;_ end of setq
      (setq tmp-obj (vlax-ename->vla-object (entlast)))
      ;; Get intersections between target and temp line
					; You had an error here. it is not
      ;; (setq ints (vlax-curve-intersectwith tgtEnt tmpE acextendnone))
      ;;it is so
      (setq ints-var@tgt (vla-intersectwith tgt-obj tmp-obj acextendnone))
      (setq ints@tgt (VLAX-SAFEARRAY->LIST (VLAX-VARIANT-VALUE ints-var@tgt)))
					;(setq point@tgt (VLA-ADDPOINT model ints-var))
      ;; Get intersections between base and templine
      (setq ints-var@base (vla-intersectwith base-obj tmp-obj acextendnone))
      (setq ints@base (VLAX-SAFEARRAY->LIST (VLAX-VARIANT-VALUE ints-var@base)))
					;(setq point@base (VLA-ADDPOINT model ints-var@base))
      (vla-delete tmp-obj)
      ;;(setq smpl-dim (ssname (ssget "_:S+." '((0 . "dimension"))) 0))
      (setq smpl-dim-style (cdr (assoc 3 (entget smpl-dim))))
      (setq smpl-obj (vlax-ename->vla-object smpl-dim))
      (setq smpl-dim-lay (vla-get-layer smpl-obj))
      (setvar 'clayer smpl-dim-lay)
      (setq at&t-style (vla-item dim-styles (VLA-GET-STYLENAME smpl-obj))) ;"AT&T"
      (vla-put-ActiveDimStyle adoc at&t-style)
      (setq dim-txt-pt (MAPCAR '* '(0.5 0.5 0.5) (MAPCAR '+ ints@base ints@tgt)))
      (setq dimObj (vla-AddDimAligned
		     model
		     ints-var@base
		     ints-var@tgt
		     (VLAX-3D-POINT dim-txt-pt)
		   ) ;_ end of vla-AddDimAligned
      ) ;_ end of setq
    ) ;_ end of progn
  ) ;_ end of if
   (VL-CMDF "regen")
  (setvar "CMDECHO" ce)
  (setvar "OSMODE" os)
) ;_ end of defun
;|«Visual LISP© Format Options»
(100 2 40 2 T "end of " 60 9 0 0 0 T T nil T)
;*** DO NOT add text below the comment! ***|;
dim to lines SCHNIPPLES cadtutor.lsp
