Locking geometry in place (model in place)
In a situation such as this...
Can I lock these values so that they cannot be changed?
When placing a sketch on another object, I'm not sure how to move/adjust everything so that it is both where and the size I want.
if I change one value, the other changes too...
Noob.
Revit 2026
Am not sure if those are temporary dimensions. They automatically appear when selecting an object, and since they are temporary, they cannot be lock AFAIK.
If you want to lock the object, better align it to a reference plane, add a dimension and lock the dimension.
another option is create a simple family.
Hope it helps.
