Hello all:
I use a code that generates 3 viewports
I would like the chain to be able to generate them in this way
that the second viewport is a side view
and the third viewport, front view
but that in the second and third viewport the UCS is aligned to the view
as in the second image
If there's any way, I'd appreciate your advice or comments
here my code
(DEFUN C:V3 () (command "_MODEL" "_-vports" "3" "l" "'_.zoom" "_e" "_-VIEW" "_SWISO"))
thanks
Ok its simple to use vpoint to set your view angles, code is part of a view choice lisp.
(if (= look "R")(command-s "-vpoint" "1,0,0"))
(if (= look "L")(command-s "-vpoint" "-1,0,0"))
(if (= look "F")(command-s "-vpoint" "0,-1,0"))
(if (= look "B")(command-s "-vpoint" "0,1,0"))
(if (= look "P")(command-s "-vpoint" "0,0,1"))
(if (= look "3")(command "_.vpoint" "-1,-1,1"))
If you want auto 3 viewports then you need to ask what scale and pick say a point in model so the views can be based around that point. I would use a layout with a title block.
  • Thanks 1
