amook147 Posted Friday at 07:12 AM Posted Friday at 07:12 AM Drawing2.dwg As shown in the figure below: Select multiple graphics in batch and change the R value from 0.2 to another value? Quote
SLW210 Posted Friday at 12:17 PM Posted Friday at 12:17 PM Are you looking for a LISP, Python, VBA, .NET, etc.? I moved your thread to the AutoLISP, Visual LISP & DCL Forum. Quote
BIGAL Posted Friday at 11:13 PM Posted Friday at 11:13 PM Code what's that for ? Join Fillet R 0.4 P pickobject enter All done 1 Quote
mhupp Posted Saturday at 12:30 AM Posted Saturday at 12:30 AM 1 hour ago, BIGAL said: Code what's that for ? Join Fillet R 0.4 P pickobject enter All done Have to fillet the 3 long arcs segments before joining. But yes no lisp needed for simple task. Quote
BIGAL Posted Saturday at 02:30 AM Posted Saturday at 02:30 AM (edited) The large arc is like the base radius for all the teeth, so changing that may need a complete redraw. behind the shape must be some form of formula, or design rules. Sounds like a custom gear.lsp is needed. Edited Saturday at 02:30 AM by BIGAL Quote
Tsuky Posted yesterday at 04:03 PM Posted yesterday at 04:03 PM @amook147 Try this With your exemple seem to work's... mdf_gear.lsp 1 Quote
SLW210 Posted 5 hours ago Posted 5 hours ago Much like Elvis, the OP seems to have left the building. In case there is a dramatic return, here is a LISP that should work, though unclear what "code" they want or or if this is for an actual plug-in. Solved: Fillet multiple polyline all at once by lisp - Autodesk Community I didn't look at Kent Cooper's version to prompt for a radius, but used the original and added something simple to it. I am sure Kent Cooper's is better. (defun C:FMP_R (/ plss n rad) (setq rad (getdist "\nEnter fillet radius: ")) (if (and rad (> rad 0.0)) (progn (command "_.fillet" "_radius" rad) (if (setq plss (ssget "_:L" '((0 . "LWPOLYLINE")))) (repeat (setq n (sslength plss)) (command "_.fillet" "_polyline" (ssname plss (setq n (1- n)))) ) ) ) ) (princ) ) 1 Quote
Nikon Posted 1 hour ago Posted 1 hour ago (edited) Lee Mac has a similar code. The FMP_R and fpoly codes perform conjugations with a given radius. Only in these codes it is impossible to set the value radius = 0. Is there a code for interfacing with a radius of 0? There's also the marko_ribar code, but I couldn't verify it. When loading, the message appears: Unknown command. Edited 1 hour ago by Nikon Quote
